Old 08-07-2009, 11:16 AM
Brian FRF is on a distinguished road
Helical interpolate vs. drill then open with mill
Looking into volumill and other things, and it seems helical on end mills is becoming the standard, as opposed to what Id call "traditional" drill a hole for the end mill, then run an endmill in to open out the hole/cavity.
Obviously this saves tool change time. Im just thinking more chance of burning up/wearing out the tip of the end mill, not sure it would be worth it.
Old 08-07-2009, 02:27 PM
*Registered User*
Glacern is on a distinguished road
If it's a matter of cycle time, then it'll depend on how steeply you can ramp. If you're cutting aluminum with a 2-flute endmill, you can program a coarse helix, cutting down the cycle time.
Harder steels requiring shallower ramping angles could benefit from drilling. Cycle times could be faster, and the dirt-cheap stub-length drills would help prolong the life of your endmills.
In a high production environment, it would be difficult to beat an indexable drill with thru-spindle coolant to hog out the bulk of the material.
Need help lathe on a mill helical or not bigtoad170 General Metalwork Discussion 5 07-30-2008 12:09 PM
Problem- Fanuc 11m won't helical interpolate hoidahl Fanuc 11 04-10-2008 05:53 AM
Drill holes with end mill or twist drill ? Argofanatic General Metalwork Discussion 15 12-29-2006 10:05 PM
Trying to interpolate X and A axis. Konstantin G-Code Programing 7 11-08-2006 11:09 AM
Fanuc 6mb do I need a BTR?? Also it wont helical mill ? mt92 Fanuc 3 10-18-2006 10:25 PM
