Old 02-26-2005, 12:21 PM
Gold Member
heilcnc is on a distinguished road
Drill Rod For Linear Ways
hi ALL I HAVE 2 CHINA MADE MACHINES LATHE AND MILL CONVERTED TO CNC BUT I WANT SOMETHING BETTER BEEN MACHINIST FOR 22 YEARS CANT GET THESE TO HOLD +,-.001 thinking of building a mill like the minitech 2 mill but use 1 inch drill rod and oilite bearing instead of thomson rod with ball bearing will this work ? thanks all picture at bottom
Old 02-26-2005, 02:27 PM
Ferenczyg is on a distinguished road
take a look to swede's webpage at www.5bears.com to take ideas about a selfbuilt machine
hope it helps
/F
Old 02-27-2005, 09:16 PM
Stevie is on a distinguished road
My lathe has round ways like your thinking of
I tried drill rod; it will not stand up; your better off to pay a bit more up front and get Thompson Chromed shafts; i got mine for $36 for $36 inches; thats 1/2" diameter
Old 02-28-2005, 11:41 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
I agree with Stevie that "Thomson" should be used or at the minimum you should harden the drill rod 60 - 62HRc
www.integratedmechanical.ca
Removal of the drill press depth stop threaded rod devinchi Shopmaster/Shoptask 4 03-14-2010 09:10 AM
Drilling a perpendicular hole in drill rod material ngr1 General Metalwork Discussion 12 12-04-2004 09:16 AM
Drill Rod Diameter Recommendations grempel1 CNC Wire Foam Cutter Machines 6 11-19-2004 09:28 AM
drill rod longer than 36"? where? CNC Darren DIY-CNC Router Table Machines 3 09-25-2004 08:17 PM
Thomson vs. ground drill rod TommyB DIY-CNC Router Table Machines 10 03-21-2004 10:08 AM
