  #13
Old 06-10-2003, 09:45 AM
Klox's Avatar
Gold Member
Klox is on a distinguished road
There is some info in the ftp section on drills, sharpening off etc...
Klox
*** KloX ***
I'm lazy, I'm only "sparking" when the EDM is running....
  #14   Ban this user!
Old 06-10-2003, 11:43 AM
hardmill's Avatar
hardmill is on a distinguished road
Fraisage de cuivre -Copper milling
Just hardmill's .02 worth
Je rectifie habituellement des exercices pour couper exprès des thousanths d'un couple au-dessus de taille. Ainsi il encavateur de does'nt. Tour négatif de râteau non neccesary sur un OR. Il encavateurs parce que le matériel veut se fermer vers le haut sur le diamètre de foret.
paix
chinese:
我通常研钻子故意以切开夫妇thousanths 在大小。如此它does'nt 劫掠。消极犁耙把戏不neccesary 在北卡罗来纳。它劫掠因为材料想关闭在钻子直径。
spanish:
Muelo generalmente los taladros para cortar adrede thousanths de un par sobre tamaño. Tan él gancho agarrador del does'nt. Truco negativo del rastrillo no neccesary en un nc. Él ganchos agarradores porque el material desea cerrarse para arriba en diámetro del taladro.
English:
I usually grind drills to purposely cut a couple thousanths over size. So it does'nt grab. Negative rake trick not neccesary on an nc. It grabs because the material wants to close up on drill diameter.
Just wanted to cover all bases
In case your all wondering , yes i took the day off.
PEACE
  #15   Ban this user!
Old 06-10-2003, 06:02 PM
eponyme-le is on a distinguished road
hehe ,I better understand english than your french :d
  #16   Ban this user!
Old 06-10-2003, 08:10 PM
hardmill's Avatar
oh well...
I tried........
http://babelfish.altavista.com/
paix
Old 06-11-2003, 02:07 AM
Klox's Avatar
Gold Member
Humour
Hey Hardmill,
I ENJOY your humour tremendously !!
I did not understand a single word of french you posted but i promise i won't nuke you for that!
Keep well, see you
Klox
NS! I might consider moving your post to French "Bad Language" forum (Chuckle)
*** KloX ***
Thread milling, can anyone help jtrav General CAM Discussion 16 03-06-2006 02:25 PM
Why would this machine be bad for milling? jevs Knee Vertical Mills 5 06-16-2005 10:49 PM
Heads Up - Article about building CNC Milling Machine samualt CNCzone Club House 3 06-13-2005 02:43 PM
milling copper (99%) nervis1 General Metal Working Machines 3 09-26-2004 06:34 PM
Pouring Silver insert into copper hole NeoMoses Casting Metals 8 10-15-2003 03:26 PM
