Old 02-24-2005, 09:23 PM
cbass is on a distinguished road
Low speed spindle?
Hi everyone,
I am planning on purchasing a small cnc router (probably from k2cnc) to machine, among other things, ceramic substrates of various different types. From the examples I've found, this will require milling speeds of anywhere from 1000-6000 RPM. All the wood router heads I've looked at (ie. Makita, bosch etc) start higher than this and probably don't develop much torque untill much higher speeds.
I've looked at higher-end spindles (like colombo, perske etc.) but they too won't go down to 1000 RPM.
I assume milling machines' heads will do this but they are probably very heavy and large, and will cost a fortune.
Any suggestions on a spindle that might suit my needs?
Old 02-25-2005, 03:38 AM
RotarySMP's Avatar
RotarySMP is on a distinguished road
Sherline industrial ER-16 spindles. You will have to relax the bearing preload a little for continous operation above 2000rpm (detailed procedure from Sherline supplied with the spindle.
Regards,
Mark
www.wrathall.com
CNC Controlled Spindle motor speed control gregmary General Electronics Discussion 13 02-27-2009 07:01 PM
Machine Aluminum... Spindle speed and flute count ngr1 General Metalwork Discussion 6 01-03-2005 11:35 PM
Spindle Speed & Feed Rates - Question Moondog DIY-CNC Router Table Machines 1 07-23-2004 06:24 PM
Low speed chatter Don C Gecko Drives 2 04-07-2004 09:27 AM
Installation of spindle speed sensor Bloy2004 General Electronics Discussion 7 01-27-2004 09:50 PM
