Old 03-07-2003, 05:14 PM
HuFlungDung's Avatar
Moderator
Sealing a collet?
If you've bored parts in a 5C collet, you know how much of a nuisance it can be to keep the chips from falling through the slots in the collet and getting in between the tapers of the clamping surfaces.
It occurred to me today to use a hot glue gun to seal the slots. Since the 5C collet does not have a lot of flex range, the glue still seems to be flexible enough to allow the collet to collapse properly.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!Share on Facebook
Old 03-07-2003, 10:50 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
HU,
I'm going to wait until the BRIDE is asleep and raid her sewing/craft closet. I know she has one of those glue thingies in there somewhere.
Wish me luck.
Good to see you on this baord.
WMS
Old 03-08-2003, 06:42 PM
Moderator
Hi WMS,
Yep, its even worth buying your own hot glue gun for. It works great. "Hot glue" is not glue but melted urethane, which is a rubbery sort of plastic.
I never thought of it before, but a hot glue gun could be used as an injection molder for small parts.
Old 03-17-2003, 10:49 PM
jimmyb is on a distinguished road
What an interesting idea, I'll keep that one in mind
Old 04-04-2003, 11:07 PM
David is on a distinguished road
We use silcone in the gaps of our collets. It's permanent and flexible.
David
Old 04-04-2003, 11:10 PM
Moderator
Hey, no fair, David! You planned ahead. I needed my collet sealed in 30 seconds
Old 04-13-2003, 06:36 PM
9566317 is on a distinguished road
We have used silicon for a number of years but here is one for you,Thru spindle collant on mill,
make a plug that fits into the front of the collet with holes drilled on a tapper to direct the flow of coolant to your cutting edge.On a lathe just hook your collant line up to the back of the tool and let the coolant go thru the collet for better
toll colant and lubercation
1/4 to 1/8 collet adapter? CRFultz DIY-CNC Router Table Machines 6 04-17-2010 02:54 AM
Calculating draw bar force on R8 collet h3ndrix General Metal Working Machines 8 07-27-2005 05:51 PM
Your opinion on adapting my router collet MrBean DIY-CNC Router Table Machines 5 12-03-2004 12:02 PM
Looking for ER40 collet drawings svenakela General Metal Working Machines 12 08-21-2004 05:39 PM
What is this collet size? kong General Metal Working Machines 2 06-06-2004 02:07 PM
