Old 07-28-2009, 03:57 AM
Snowie's Avatar
Snowie is on a distinguished road
Unhappy Ikegai AX20N CNC Lathe power up troubles
Hi people
I've just installed a older Ikegai AX20N CNC Lathe an having a power up issue's. When you press the on button on the main coltrol panel the screen fires up and the fans start in the rear control cabnet....But does the Aux hydraulic pump suppose to start as well?? The error on the screen is 401 servo but you can cycle threw most of the screen etc
Snow
Old 07-28-2009, 10:19 AM
cncdiag is on a distinguished road
Try reversing two phases of the incoming power
Old 07-28-2009, 03:17 PM
Snowie's Avatar
Thank. I'll give that a try. Will keep you posted
Old 07-29-2009, 11:59 PM
Snowie's Avatar
No good, well at least the forward button makes the swarf conveyor go in the right direction. Coolent pump not going either. But they go when you press the manual button on the start relay. Tracing the curcurt now of the switching wire.
Cheers snow
Old 08-01-2009, 01:32 PM
gridley51 is on a distinguished road
Is it a fanuc 6T control?
Old 08-01-2009, 05:18 PM
Snowie's Avatar
Hi all
Loose relays on main board and 2 bowen fuses.Yip it's a T6 controller. I'm new to this type of controller and Am used to a MACH controller (Would love to do a conversion). How do you get the spindle going. Do you have to load speeds in to the controller on the T6. Just pressing the entry button while the chuck direction is selected and chuck closed light is on. Nothing happends??
Thanks Snow
ikegai fanuc fx lathe 5t control caddyshack 5T/5M 20 11-19-2011 06:39 PM
Need Help!- IKEGAI EC-18 lathe info. CATCH22 General Metal Working Machines 0 03-10-2009 10:29 PM
Ikegai A 20 lathe manual jklingel Want To Buy...Need help! 0 02-04-2009 05:10 PM
Need Help!- IKEGAI AX15Z LATHE PARAMETERS !!! party o one Fanuc 7 12-01-2008 11:41 AM
Ikegai FX20N lathe gridley51 General Metal Working Machines 9 11-17-2007 06:19 PM
