Old 07-27-2009, 06:07 PM
zaebis is on a distinguished road
CNC Threading on a mill ??
Ok looked at youtube how ppl execute large threads (2-3 inches in diameter). I need to come up with a way for my little CNC mill to thread (1 1/2' diameter) male/female and it has to be done without spindle speed/feed synch (e.g. not tapping but interpolating around with a threadmill). Even though there are millions of end mills available I cant seem to find those umbrella shaped threadmills anywhere. So;
1/ who sells those
2/ where can I get info on which tool can create what thread
Old 07-27-2009, 07:54 PM
PixMan is on a distinguished road
If you're referring to single tooth thread mills, a good source is Scientific Cutting Tools. To use it your mill will have to have 3-axis interpolation; the ability to circle mill while dropping or raising Z.
Old 07-27-2009, 07:57 PM
JPW JPW is offline
JPW is on a distinguished road
I have used a "Criterion lathe threading tool style Z" to cut internal threads. I have used it in a 1/2" collet or in a boring head. The boring head allowed adjustment without reworking the program. Radial relief to accommodate thread pitch is built into the tool.
http://www.criterionmachineworks.com/
This may help you find the appropriate tool.
Old 07-28-2009, 07:02 AM
Andre' B is on a distinguished road
http://www.harveytool.com/products/s...thread+milling
Also Travers Tool, MSC, etc..
Or most lathe threading bars can be used.
Threading MDF Me2 FAQ of CNC Machine building 5 05-26-2011 12:08 PM
Help with threading on a CNC mill shorety General Metalwork Discussion 9 06-13-2009 09:15 PM
G76 threading mcm1961 General Metalwork Discussion 1 02-13-2008 05:36 PM
Using the Mill as a Lathe; Single Point Threading Geof Haas Mills 10 02-07-2008 01:28 PM
Internal threading on a cnc mill jime General Metalwork Discussion 5 11-14-2007 09:42 AM
