Old 07-25-2009, 01:58 AM
twocik is on a distinguished road
What material is this ?
Any idea what material the triangle piece the wheels are attached to in the picture ? It looks like steel, but wasn't sure if it was some kind of special grade (doesn't rust).
http://www.cnczone.com/forums/attach...1&d=1248505012
Old 07-25-2009, 05:13 AM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
It looks like yellow zink plated steel
Old 07-25-2009, 07:52 AM
PixMan is on a distinguished road
It's impossible to tell for certain with just a photo, but you can run one simple test to narrow it down. Magnet! If the magnet sticks, it's probably a zinc chromate plated steel. If the magnet doesn't stick, it's probably a low-grade stainless steel.
One other thought: If the color balance of the photo is too warm, that golden color might be in the lighting and not the part. It could also be a nickel-plated steel and if plated thick enough the magnet might not stick. Looking at it again, I think the plates are 304 stainless because the triangular weldment on them is "yellow enough" to be zinc chromate plated soft steel. I can see any weld between the two pieces, but in the lower left piece there seems to be some glob of goo between the two metal pieces. The finish on the plates looks like a rough grind from a hand held angle grinder, often used for post-weld spatter removal.
Old 07-25-2009, 10:33 AM
Doesn't have to be exact, I'm looking for something strong enough to hold 400 lbs and not have to worry about rust or having to have it painted. What this is for is a camera dolly. Here's a picture of what I'm talking about
http://www.digitalfilmgroup.com/imag...a_dolly_sm.jpg
I only work with aluminum, so this is out of my area. Any suggestion on where to get this material ?
Old 07-26-2009, 12:33 AM
RogerRetro is on a distinguished road
My guess is that it is Zinc Dichromate or Gold (Dichromate) Cadmium plated steel.
Regards,
Roger
Old 07-26-2009, 01:00 AM
hgk hgk is offline
hgk is on a distinguished road
This one is using Aluminum angle.
Old 07-27-2009, 09:59 AM
I've made plenty of dollies using the angle material, just wanted to step up the strength. The angle stuff works pretty good, but not like the steel triangle. I don't know where to find it, any suggestions ?
Old 07-27-2009, 06:46 PM
garagefela is on a distinguished road
Couple of choices here and each is not a difficult solution.
The first design looks like a good thing to copy. Base plate and angle just use mild steel and either galvanise dip, passivate, cad plate, normal paint, powder coat or zinc plate just to prevent the rust. Mild steel will be plenty strong. Many many easy and low cost finishing choices there that will do the job perfectly.
Not having been involved in filming I can't see you tearing around in driving rain and would think the dolly trucks will last ages.
Or make the base plate and angle out of stainless steel, bit more expensive and a bit harder to work with but by no means impossible and then they will last forever but as mentioned earlier are you going to be using this thing along the beach and in the water? I would guess most probably not.
All depends if you want overkill or not.
Cheers M
No, Little-Johnny, pomegranate is not a type of English stone.
Old 07-27-2009, 08:08 PM
hgk hgk is offline
The triangle is likely a special fabrication which would probably require a thomasnet hunt.
http://www.thomasnet.com/products/tu...8674080-1.html
-George
Old 07-29-2009, 06:51 PM
Oh.... Yea I've looked all over, nothing...
Wow is that a congested site
If anyone else might know of a place, please feel free.
a36 material xmaldinix General Material Machining Solutions 3 06-20-2009 12:03 PM
What material is better 304 or 303 Joseph Souza General Material Machining Solutions 5 08-06-2007 05:26 PM
Material??? Grass-hopper JGRO Router Table Design 1 01-25-2007 06:21 PM
Material ryanduc General Material Machining Solutions 0 01-29-2005 06:50 PM
Material ID DLMACHINE General Metal Working Machines 1 02-24-2004 07:58 AM
