Old 07-21-2009, 12:50 PM
HPT HPT is offline
HPT is on a distinguished road
Question What is the right VMC to do the job??
I have an application where holes having 1.5" diameter are to be drilled in a 4" thick flange. Material is 4140 having 220 BHN hardness. Bolt circle diameter is 18". Have been using radial drill machine. Need to go for a VMC so that we can use drills with indexable inserts. Any inputs on specs for a suitable VMC will help. Can a machine with BT40 taper do this job?
Old 07-21-2009, 03:10 PM
I think you might need plenty of horspower and high pressure through spindle coolant. If you were choosing a Haas machine my guess is that it should be a VF3 or VF4 with gearbox (which may be standard I am not sure).
