Old 07-20-2009, 02:55 AM
yaddatrance is on a distinguished road
Buy/make a top nut for an Aloris BXA QCTP?
I had put away an Aloris (genuine) BXA set a few years back, and now that I dragged it out to install on a new machine I found that I'm missing the top nut.
Does anybody know what the thread on that nut is?
Or... if folks don't recommend that I just turn one or grab an off the shelf nut... Where I can buy just that top nut?
I did a search in google and CNCzone and didn't find anything related...
Thanks for any advice!
Old 07-20-2009, 05:14 AM
ftkalcevic is on a distinguished road
I don't know about the BXA, but my AXA "clone" had a metric 14mm x 1.5mm fine thread.
Old 07-20-2009, 10:09 AM
donl517 is on a distinguished road
You can order an original through MSC industrial supply. Be prepared to pay through the nose though. Aloris has a minimum order and MSC gets a good chunk too! Best bet would be to download the pdf catalog from Aloris's website and see if it gives the thread size, then order a generic nut.
HTH,
Don
Old 07-22-2009, 12:33 PM
Thanks for the tips...
The import nut seems to have a different pitch than the aloris.
Does anyone know what page in the MSC big book it's on? i tried near the p.1606 but I didn't see one, just the T-bolts.
Also if anyone knows the actual pitch, that'd be great too! I couldn't find it on Aloris' site either...
Old 07-22-2009, 12:38 PM
You won't find it in the book, you'll have to call MSC and they will call Aloris and quote you a price. If your lucky maybe they will tell you the thread size.
What is the diameter of the screw?
Don
Old 07-22-2009, 12:46 PM
It's a 5/8" or something really close to a 5/8"
Old 07-22-2009, 12:49 PM
The post on my CXA is a 3/4-16 - I'm surprised that it is a standard fine thread. According to the Alrois 2006 price list the Flange nut for the BXA is $11.00, don't be suprised if your quoted $20.00 or more.
I found some dimensions in the price list, it says the BXA has a 5/8 shaft so I'm assuming it is 5/8-18 thread, based on what my CXA is.
HTH,
Don
Old 07-22-2009, 01:03 PM
Thanks for the info! If your CXA is a standard then I'd also guess that mine is too. I didn't want to try cranking on random nuts and crossthread the bar.
Those better be some gold plated nuts
Old 07-22-2009, 06:34 PM
KIMFAB's Avatar
KIMFAB is on a distinguished road
This might be an ideal time to invest in a screw pitch gage. A cheap one is usually included with a tap and die set or one can be purchased separately.
I used to be appalled, now I'm just amused.
C6 Lathe QCTP john_t_h Syil Products 4 11-13-2008 04:48 AM
Which Aloris Model? jimgarner Haas Mills 1 03-09-2007 09:06 AM
anyone using a QCTP? dahui Shopmaster/Shoptask 0 05-04-2006 08:08 AM
Another 8x12 mod - QCTP pjeran Mini Lathe 0 04-21-2006 11:43 PM
Has anyone tried HF QCTP James04 General Metal Working Machines 3 04-23-2003 02:03 AM
