Old 07-17-2009, 10:01 AM
323ci is on a distinguished road
UPI servo board
Having problems with turret initialization...
We have a J&L lathe (circa 1984), single side turret, UPI with AB 8200 NCU.
The issue is this... when initializing the turret will unclamp, begin to move and then quit. There are no fault messages, EVERYTHING appears normal. The servo drive can be operated manually by using a 9 volt battery so the drive is fine. Once it quits no more control of the turret is possible until a complete power down at main disconnect as the upi remains powered up with control off. Seems to be servo board related... there is +11.9/-11.9 coming from the servo board to drive. The resolver has been setup for this board using scope. Pretty sure this board is bad. Any ideas on what could be bad on this board if this is the problem?
Need Help!- Board Selection for servo and stepper Kel05 LinuxCNC (formerly EMC2) 3 04-10-2009 01:33 AM
Need msi servo drive board 1933ford Tree 6 01-08-2009 08:47 PM
Need help on Servo Dynamics board SDFP1525-17 Twil759 General CNC (Mill and Lathe) Control Software (NC) 0 11-28-2007 11:33 AM
Servo Controller BOard venomx999 Servo Motors and Drives 1 12-27-2006 12:37 PM
Servo Board Failures CNC_Newbi Servo Motors and Drives 7 06-15-2006 09:07 PM
