Old 07-11-2009, 07:41 PM
Speedygonzales is on a distinguished road
lathe oils (way, cutting etc) help
I posted this in the Taig forum, but this is probably the same as every other machine in regards to its needs.
1) what do you guys use for your ways, bead on the taig lathe?
can I use 3in1? or whats recommended?
2) the top carriage, what do I use on the screw? lithium grease?
3) what do you use for cutting fluid? (all around purpose ie aluminum, brass, steel etc)
Suggestion for swiss cutting oils EvansMachine CNC Swiss Screw Machines 18 03-11-2011 08:34 PM
tapping oils.. srmaietta General Metalwork Discussion 2 08-17-2008 12:37 PM
Need info on Cutting oils widgitmaster General Metal Working Machines 16 04-03-2007 03:14 PM
oils for Cincom F12 emilm General Metal Working Machines 1 09-27-2005 06:40 PM
Problem cutting arc with lathe. mudwhump G-Code Programing 9 05-23-2004 01:19 PM
