Old 07-09-2009, 10:07 PM
xclr82xtc is on a distinguished road
gantry z axis question
hey guys, im gonna have a fairly wide, heavy z axis. 4 20mm tool steel rods, the spindle, the b axis stepper and gears, and the motor for the spindle....along with all the linear bearing and what not...
can anyone tell me a good way to control the z axis, so that both side will rise at the same rate? i was thinking to use the motor on one side, connected to a shaft, have the shaft with a gear at each end that would mesh with a gear rail in the frame. controlled by one motor...i think the backlash would be minimum because of the weight of the machine, but im not sure doing it without a gearbox on the stepper would have enough grunt.
how would you do it?
Old 07-10-2009, 06:46 PM
no one has any ideas?
Old 07-11-2009, 03:57 PM
awerby is on a distinguished road
Are you the same guy
that was proposing this in another thread? If not, maybe you and HellBringer should put your heads together:
http://www.cnczone.com/forums/showth...339#post636339
Personally, I think this sounds pretty difficult, but as the machine he pictures shows, it's not impossible (although you don't see many of these, for some reason)...
Andrew Werby
www.computersculpture.com
Old 07-13-2009, 05:27 PM
i have decided to forgo having any latereal axis on the table. and will just use the table for the "c" axis. i will build all the lateral axis's and the b axis into the gantry
Newbie question on old gantry table LJG General CNC (Mill and Lathe) Control Software (NC) 1 06-29-2007 11:14 PM
Gantry rail question millman52 CNC Plasma and Waterjet Machines 19 12-21-2006 07:13 AM
Dual Drive Gantry Question? Syphontek CNC Plasma and Waterjet Machines 12 03-13-2006 12:51 PM
moveable table/gantry question Kev DIY-CNC Router Table Machines 3 10-29-2005 06:24 PM
Gantry design question anthony Mechanical Calculations/Engineering Design 2 04-27-2005 02:39 PM
