Old 07-09-2009, 09:23 AM
andywids is on a distinguished road
Exclamation Error 414 Z-axis error detect servo alarm
I'm using a Hwacheon Ecomil 65V with Fanuc 18M brain. Upon startup, the oil cooling unit does not turn on as it normally should and I'm given an error "414 Z-axis error detect." I am not able to move the machine or start the spindle. I have had this problem before and have resolved it previously by filling the hydraulic oil reservoirs as they were low. The oil has been filled and the machine was running fine yesterday. Today the machine produced the error upon startup and the oil levels are all fine. Any ideas?? Thanks a lot
Andrew
Old 07-09-2009, 10:56 AM
yours_prabhat is on a distinguished road
Question Z servo error
please give the correct drive specs , Whereas you can check the signals by logic which are responsible to make drive enables , If the problem persists can call or communicate me on +91-9430737981 or on prabhatmishra@mail.com
Need Help!- HAAS VF-2 (104 ALARM) Y SERVO ERROR TOO LARGE joanpim Haas Mills 3 09-12-2011 05:24 AM
410 Alarm X axis ecess error scuba Fanuc 8 03-07-2011 08:13 PM
Help! alarm 414 X axis detect err CVMW Fanuc 8 01-10-2009 08:42 AM
alarm 105 (z servo error toll large) on Haas VF-OE hoi.le Haas Mills 4 08-12-2008 06:01 AM
434 servo alarm: Z axis detect error padobranac Fanuc 19 07-30-2007 04:12 PM
