Old 07-08-2009, 06:59 PM
BMG BMG is offline
BMG is on a distinguished road
1994 Bench Lathe TY-C0632 by Yangzhou Machine Works
I recently picked up this Lathe from Craigslist (thanks Brent).
The lathe has some damage - yes it was dropped off a truck. As the seller stated, his offering price was close to the scrap value of the unit. Unfortunately, no manuals, part lists and the like were available. I have been searching the internet and I cannot seem to find much information on this model machine. Many of the importers that brand them under their name appear to have similar if not identical lathes.
Can anyone offer suggestions where I might find documentation on this machine? I am aware it is likely to havepoor translations and the like, but parts drawings would certainly be very helpful.
Thanks.
BMG
Old 07-09-2009, 08:01 PM
BMG BMG is offline
I did not have my camera yesterday.
Below are pictures of the unit. It appears near identical to Grizzly's 13.5 X 40 Gear Head Lathe.
THe unit fell over in a truck and the handles on the front side took the brunt of the fall. The leadscrew in the cross slide was damaged and needs replacement. All of the handles were bent or completely broken off.
Aside from the damage, the unit came with a 13" faceplate, extra gears and a 4 jaw chuck. None of these items were ever used. The bed ways are in good condition with little visible wear. The motor is 110/230V. All the gears shift smoothly in both forward and reverse.
The only visible wear is on the jaws for the 3 jaw chuck. The seller indicated the unit was used to face reconditions printing press parts and little else. The leadscrew for the power feed was out of the machine and appears to have never been used.
For what I paid ($150), if it was complete junk, I should have no problem getting my money back scrapping the bad parts and selling the rest. For now, I plan on resurrecting this and use it to learn metal machining.
Still searching for a source of part lists and manuals. I sent an email to the manufacturer. Maybe I will hear something.
BMG.
ID:	84147   Click image for larger version
ID:	84148   Click image for larger version
ID:	84149   Click image for larger version
Tags
c0632 yangzhou
New Lathe, bench, Vectrax 14-40 ozzie34231 General Metalwork Discussion 4 12-23-2007 09:14 AM
Bench lathe Conversion Kit tootalew Mini Lathe 6 03-08-2007 01:11 PM
What power supply for my bench top cnc machine xcphil General Metal Working Machines 8 04-17-2006 02:47 PM
Big Bench Top Machine Conversion yukonho Benchtop Machines 2 11-16-2005 12:27 AM
Bench Machine or Full sized, CNC or not? Compufobia General Metal Working Machines 24 10-28-2005 09:52 AM
