  #13   Ban this user!
Old 07-08-2009, 08:21 AM
Originally Posted by davereagan View Post
You could have massaged the keyway in the problem collet with a die grinder in less time than it took to stroke down this post.
But isn't it much more fun to get into a cat fight?
  #14   Ban this user!
Old 07-08-2009, 09:23 AM
One of Many is on a distinguished road
Meow Psssthh
4-6 R8 regrinds a week? Maybe in a spindle shop where the casualties gather. The average manual job shop back in the day, it was very common to run old Bridgeports without the key present and nary a problem with precision.
Some old school machinists would back out the key intentionally. It wasn't always removed leaving a hole. I'd guess the practice started once the original keys got sheared off at some point. Once you've gone keyless, you don't always go back unless there is a need. Like in the events of an add-on power draw bar or hamhanded constant collet/draw bar thread abuse. A 5/32 square key is certainly not a 1-3 HP transfering driver like they bigger 30-50 tapers running 5-30hp.
Mishaps are not going to care whether the key is there or not. Just don't do what I witnessed one "skilled" chap doing. Remove the darn key before attempting to beat out the spun holder, with the draw bar and a big hammer!
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
  #15   Ban this user!
Old 07-08-2009, 09:44 AM
davereagan is on a distinguished road
Much more fun to catfight, hence my reply. Why would a shop be adding 4-6 collets a week?
  #16   Ban this user!
Old 07-08-2009, 09:58 AM
Originally Posted by One of Many View Post
....Mishaps are not going to care whether the key is there or not. Just don't do what I witnessed one "skilled" chap doing. Remove the darn key before attempting to beat out the spun holder, with the draw bar and a big hammer!
DC
Yes, a hard key and a soft tool holder shank is the wrong combination; the key acts as a good grooving tool when the holder slips in the taper. Fortunately my machine had a soft key so the key sheared and the holder came out okay.
  #17   Ban this user!
Old 07-08-2009, 04:31 PM
Grooved and all, they sure don't come out the way they went in, do they.
As I have mentioned in other threads in being very selective on my collet or holder shank profiles. I do try and avoid the necked down holders where the key rides. There can end up being about a 30% reduction in the key contact depth due to that area being smaller in diameter. All it takes is a slightly warn key or key slot and the right circumstances to ruin your day. Not all R8 tooling is made equal.
DC
drill chuck proper use? taper came loose... radioactive General Metalwork Discussion 7 05-11-2009 06:38 AM
Fitting to Taper shaft Al_The_Man General Metalwork Discussion 14 03-27-2008 12:18 AM
Chuck Drill Chuck Alignment TomV Mini Lathe 5 04-27-2006 01:20 AM
M6 x 1.0mm grease fitting N4NV Mechanical Calculations/Engineering Design 5 03-31-2006 04:03 PM
cnc fitting a bridgeport MBG Bridgeport and Hardinge Mills 5 09-26-2005 04:25 PM
