Old 07-02-2009, 05:03 PM
wganders is on a distinguished road
Lagun Mill Gibb Stuck
We have a Lagun vertical knee mill and the Y-axis is really hard to move. I've tried taking out the gibb but the adjusting screw only moves about half a turn. Do you think the gibb is just rusted in place? Is there an easy way to unjam the gibb?
We picked the mill up at an auction and are just trying to get it going.
Also, the slot head gibb screw has a slotted nut around it and I was wondering what the purpose of the nut is.
Thanks,
Wganders
Old 07-02-2009, 10:17 PM
MattTheNoob is on a distinguished road
Maybe an obvious point, but make sure the gib lock is loose. In other words, there is probably a little handle that locks that axis... or perhaps there was and the handle is broken off, leaving just the threaded stud tight against the gib.
After that, take the gib screw from the large end of the gib all the way out and then move the table toward the small end. Ideally, the table should jut walk right off of the gib. If not, tighten the screw on the small end of the gib until it breaks the gib free (or until you feel like you might break something else). It it is rusted in place, it is probably worth pulling the whole table off and making sure the ways are clean. You may be able to tap the small end untl it breaks loose, but use an aluminum "punch" or other soft material so you don't swage the end of your gib.
I'd say the nut is probably a lock nut, though I haven't seen that on a mill before. Maybe someone's creative alteration?
Old 07-03-2009, 10:12 AM
Thanks for the reply/tips. The table lock is loose but I didn't think to check if there may be two locks, with one being broken.
Have a great 4th!
Wganders
Tags
gibb, lagun, maintenance, mill, repair
Problem- Leveling a Lagun Vertical Mill donl517 General Metal Working Machines 2 12-14-2008 01:41 PM
Lagun mill powered knee jjclear Knee Vertical Mills 3 12-03-2008 02:29 PM
Lagun 310 Stuck Spindle mcsf Knee Vertical Mills 5 06-07-2008 06:13 PM
Lagun Mill (BP clone) CNC conversion How To? Kerry Harrison Bridgeport and Hardinge Mills 16 08-24-2007 01:23 PM
Lagun Mill (BP clone) CNC conversion How To? Kerry Harrison Stepper Motors and Drives 0 08-20-2007 08:31 PM
