Old 06-30-2009, 07:45 PM
Arquibaldo is an unknown quantity at this point
allowable weight on a lathe spindle?
Dear machinists:
I own a 9" South Bend clone, with a 1.5" spindle, threaded 8 TPI, bored MT-3
and running on tapered roller bearings. Could an experienced lathe machinist
give me an educated guess on the allowable weight (chuck+work) on this spindle?
I realise that leverage also plays a role, so the longer the (unsupported) work,
the smaller the weight should be, right?
I ask because I bought a new 160mm (about 6") 4-jaw chuck, which seems quite
heavy: 10.6Kg (about 23 lb), including the mounting plate. Overall length
is 100mm (4") from the end of the spindle thread to the tip of the jaws.
Will I be able to use this chuck, with something like say a 10 Kg (20 lb) work,
without bending the spindle or damaging the bearings?
Nelson
Old 06-30-2009, 08:03 PM
No problem. The spindle and bearings will be capable of carrying a load in the hundreds of kg.
If you want to get an idea of the load carrying capacity of bearings the size of the ones in a lathe spindle just consider they are about the same size as those the wheels of motor vehicles. They can carry a load far bigger than you will ever put in the machine.
Need Help!- Lathe spindle speed and lathe facilities GuntisK TurboCNC 4 10-26-2008 06:22 PM
Lathe spindle bearings and spindle material mackeym General Metal Working Machines 28 08-21-2007 03:49 PM
Lathe spindle bearings and spindle material mackeym Linear and Rotary Motion 1 08-11-2007 11:53 AM
Allowable noice levels ullbergm Safety Zone 26 02-12-2007 07:29 AM
MIC-6 jig plate allowable loads? walter Mechanical Calculations/Engineering Design 6 10-24-2005 05:18 PM
