Old 06-29-2009, 11:29 PM
mod_o_matic is on a distinguished road
CMM Machine
Sorry if this is in the wrong place...
CMM machines. Just want some information on them. Are they easy to use? Can they create CAD files that i could open in Pro-E?
Basically, if i have a part and want to recreate it using a CMM what are the steps involved?
Old 06-29-2009, 11:41 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
as far as ease of use , they are as good as the guy using them , for example if a guy is using a manual cmm and he's had one too many coffee's or is hung over and has the jitters then the readings on tight tolerance stuff can be all over the place
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 07-01-2009, 01:40 PM
keebler303 is on a distinguished road
So you're looking to reverse engineer a part?
Depending on the complexity of the part, it may be easy or hard with a standard cmm. With basic features, you can use the CMM to pick off points and use those as references in your pro-e model. Basically building the model as you go. This is pretty eqasy for simple parts but if you're dealing with freeform shapes, it becomes impossible to do by hand, at least with any accuracy. You can howevr buy a laser scanner that will mount in the cmm and will give you thousands of points per second. This gives you lots of raw data, but you still need to get it into cad. Pro-E might have point cloud import, I don't know. Even if it does, you still need to be able to smooth out imperfections, fix "holes" in the data, etc. There is software in existence which will turn the raw data into a solid model with feature tree and all but it is $$$. The name escapes me but I saw it at a presentation by Metris, who makes the laser scanners.
If you could give me an idea of what kind of parts you are dealing with and what the accuracy needs to be, maybe a better solution could be proposed.
Matt
saleCNC laser engraving machine and CNC woodworking machine zhangrui1588 Laser Engraving & Cutting Machines 3 05-08-2011 04:54 PM
Another machine rigid tapping (stepper machine) samco LinuxCNC (formerly EMC2) 10 04-10-2009 08:21 PM
sell CNC Woodworking Machine,CNC Advertising Machine zhangrui1588 Product Announcements & Manufacturer News 0 05-30-2008 09:43 AM
Deep Groove Taig machine would it be a good starter machine Fritzie15 Taig Mills & Lathes 0 09-20-2007 10:37 PM
