Old 06-29-2009, 11:23 AM
taydin is on a distinguished road
Universal mill shaking
I have a universal milling machine that is currently resting on a concrete floor. The thickness of the concrete is about 20 cm. The weight of the machine is about 1750 Kg. Because of the large weight of the machine and because I am planning to process relatively small workpieces on the machine, I thought I could get by without mounting the machine to the concrete. I just made sure all corners of the machine are resting on the floor without any gaps.
But yesterday I was using a 16 mm endmill to drill a hole into mild steel. During the drilling, the milling head and the milling table were slightly shaking, apparently in different directions. It seemed the head was moving slightly right while the table was moving left and vice versa.
Even if I want to use the mill for relatively small work, must I still mount it securely to the floor? I would like to avoid this, because:
- The machine is very heavy (3500 pounds), so moving it is a
pita.
- I am concerned that the holes that I drill to the
concrete will not match the holes in the foot if the drill bit
shifts a little (which it will do).
Any help on resolving this machine shake appreciated.
Here is a link to the machine (sorry, not english)
http://www.sitemak.com.tr/tr/index.p...=90&Itemid=116
Old 06-29-2009, 11:40 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Good chance it is not the floor points.
sounds like either slop or lack of mechanical rigidity in the machine.
Table and head could be moving due to improperly adjusted gibs, out of round collet, improperly sharpened endmill.
An endmill is not the best drilling tool as it creates more cutting pressure than is necessary, drill first and finish with the endmill..
www.integratedmechanical.ca
Old 06-29-2009, 11:49 AM
Thanks for the answer. Hmm, the end mill that I used was a very old one (more than 35 years old) and was rusted. I inherited it and more from my dad The machine is brand new, though... I will try with a new endmill and will write the result... I will also try with a regular drill to see if that makes a difference. When you say slop, do you mean the machine corners are not sitting snugly on the floor?
Old 06-29-2009, 05:03 PM
DareBee's Avatar
No
If it was only rocking on the floor the table and spindle would move together and not be an issue for oversize(oblong, whatever) holes.
The machine is either flexing or flopping.
Occasionally the shim stock will work loose under one of my bridgeport clones and it will literally move around the floor (if working it hard). Although not ideal, this has never noticeably effected the finish/sizing of the part.
Need Help!- Universal Parallel RayinNH Work Fixtures and Hold-Down Solutions 18 11-14-2009 11:03 AM
LC10 - Hyd Actuator shaking... Wade C Okuma 11 06-19-2009 11:09 AM
Has anyone experienced the Shaking? Field Worker Excitech routers 4 01-25-2009 12:59 PM
Which universal cnc mill camtd Deckel, Maho, Aciera, Abene Mills 3 11-20-2007 08:23 AM
Universal Joints Robyn Product Announcements & Manufacturer News 0 03-22-2006 05:59 AM
