  #25   Ban this user!
Old 07-08-2009, 07:12 PM
Curtis_F is on a distinguished road
Originally Posted by RICHARD ZASTROW View Post
As far as rotary encoders, you'll probably be into pricey units like Heidenhain ERA 180 etc.
Dick,
I was looking at that one the other day. It looks awesome, but I can't find a price on-line for it or its replacement the ERA 4480. You wouldn't happen to know the price range for it would you?
Thanks,
Curtis F.
  #26   Ban this user!
Old 07-08-2009, 09:04 PM
TheMillMan is on a distinguished road
i like the spindle cartridge idea i am building a cnc lathe as a senior project at Purdue and will use this idea. your bearing setup looks like a winner. i may use that config. do you see anything wrong with it? any disadvantages? and what do you guys think of it?
ps: i did see something that may be of interest to the designer, your bearings have no room for thermal expansion at the roller bearing end. however i do realize that this is a draft and you may have space at the back cover to allow for this, but the cap and threaded shoulder seem to be in contact and that is bad for all bearings in the line.
  #27   Ban this user!
Old 07-09-2009, 02:37 PM
The "floating" radial bearings are positively attached to the spindle shaft and allowed to "float" in the housing. The reasoning for that is the spindle bearings tend to put heat into the shaft more than the housing. The housing will usually dissipate more heat faster than the spindle shaft. The FD1009T is a "floating displacement bearing which allows the balls and inner race to move axially within the outer race. Designed for this application.
Also, The front or chuck end must remain fixed to eliminate heat growth towards the cutting tool(s). For that reason, the heat growth is toward the rear bearing where it can "float" away from the chuck end without moving the chuck or collet.
Curtis is building a high speed and generally lightly loaded spindle cartridge. For that app. that bearing set-up would work OK. For a typical lathe,(not overly high speed) I'd beef up the chuck/collet end with different a bearing pack to handle heavier axial and radial loads.
The driven end "floating" bearing wouldn't need as much of an increase as the fixed end.
Dick Z
DZASTR
Last edited by RICHARD ZASTROW; 07-09-2009 at 03:21 PM. Reason: explain whyfloat is at the drive end
  #28   Ban this user!
Old 07-09-2009, 03:16 PM
Curtis, My apologies, I hadn't read your last posting before I posted my last.
Ref. to FD1009T: Thats a 45 mm ID bearing
Ref. to 7010: Thats a 50 mm bearing. Do you mean ACD? If you mean 50 mm (71910 ACD) max speed is 24,000 rpm, if you mean 55mm (71911 ACD) then max speed is 24,000 rpm.
Dick Z
DZASTR
  #29   Ban this user!
Old 07-09-2009, 04:11 PM
Sorry Curtis, here I go again. Must preach.
After squinting at you drawings, I noticed the angular contact is DF (face to face). I'd suggest reversing that to DB (back to back).
Per Barden Engineering section "DB is suited for most applications having good alignment.................... It is also preferable where high moment rigidity is required, and where the shaft runs warmer than the housing.
DF mounting is used in few applications - mainly where misalignment must be accommodated. SPEED CAPABILITY IS USUALLY LOWER THAN A DB PAIR OF IDENTICAL PAYLOAD."
Also, remember the wider the angular contact bearings are spaced apart (within reason) the stiffer the assembly. However, heat build up between the bearings will increase the preload. Rule of thumb: 1 bearing width between bearings 13mm bearing width = 13mm spacers, both exactly the same.
Enough for now, Dick Z
DZASTR
  #30   Ban this user!
Old 07-09-2009, 04:29 PM
thanks for the explanation, i don't know much about spindel setups so this thread is really going to help.
Dick Z
Newbie- Design questions elz DIY-CNC Router Table Machines 6 04-20-2009 10:37 PM
Plasma design questions HMD CNC Plasma and Waterjet Machines 3 12-21-2007 08:37 AM
MCX Design questions Shotout Mastercam 5 04-02-2007 11:30 AM
Design Questions hani_a General Electronics Discussion 1 07-21-2006 02:45 PM
A coulple questions about GUI design... murphy625 CamSoft Products 7 04-02-2005 04:54 PM
