Old 06-22-2009, 05:40 PM
klaymonster is on a distinguished road
Arrow A Few X3 Questions
I'm currently considering getting an X3 from Harbor Freight and I’ve come up with a few questions.
1. Can the X3 cut its own CNC motor mounts before I do the conversion to CNC? (Assuming I become somewhat proficient with it)
2. Its listed with great Z-axis travel (18 inches) but I’d imagine the cutting depth is still limited to the length of the bit so several inches about is that true?
3. Is the resolution/rpm of the X3 such that I’d be able to make smooth 3D surfaces on it? Will it be so rough and stepped that polishing it to a near shine would take as much effort as the initial design and setup and necessitate an artist's naivety and ambition?
Thanks a lot guys I apreciate the time.
Old 06-22-2009, 06:41 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
Klaymonster,
A very good surface finish can be obtained when a small step over is used.
A mirror finish will require polishing.
Yes it is possible to cut your own motor mounts on the X3.
You will need a lathe to machine the lead screws.
Extra long length end mills are available 6 - 8 inches, multiple passes are required for deep cuts.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 06-22-2009, 08:02 PM
Question
Hmm Interesting.. Does anyone know where i might find the CNC upgrade packaged as a kit?
Also what is the biggest pocket i could realisticly make on one of these things? .. the biggest dimension block and the biggest pocket i could cut out of it? Thanks again all..
Old 06-22-2009, 08:04 PM
jalessi's Avatar
http://www.cncfusion.com/smallmill1.html
Old 06-22-2009, 08:38 PM
jalessi's Avatar
Old 06-22-2009, 10:22 PM
Thanks a lot Jalessi. Very helpfull information that website especially. Does anyone know for sure how big of a block i can work with on an X3?
Old 06-29-2009, 11:50 AM
Question
Anyone? how big of a block can I work with on an X3? It lists as having area of
(15 7/8") x (5 3/4") x (14 3/4"); so am I to believe i could stick a block having those dimensions onto it and start cutting?
Also it lists as having Spindle travel of (3 3/8") so to make a pocket to or near the bottom of the block it couldnt be a block much taller then that is that correct? thanks!
Old 06-29-2009, 01:43 PM
jalessi's Avatar
Post
Klaymonster,
If you CNC the X3 the Z travel would be the amount the head moves up and down not the Spindle travel.
Most CNC users completely lock the spindle so it never moves up or down.
The Y and Z axis will be your limitation, you could re index the X axis and use long material.
Jeff...
CNC mill questions - thrust bearings, leadscrew mounting, general questions tonofsteel DIY-CNC Router Table Machines 8 02-03-2012 04:42 PM
Brass vs Aluminium Vs Steel, questions, questions and questions... alexccmeister General Metal Working Machines 25 08-15-2011 01:40 PM
Some questions about the X2 (CNC) The Blight Benchtop Machines 0 02-22-2007 02:10 PM
IH CNC Questions krymis Industrial Hobbies (Support forum) 105 10-26-2006 11:49 AM
Few questions fzmn321 Hobbycnc (Products) 4 05-08-2006 05:04 PM
