Old 02-12-2005, 10:31 AM
sendkeys is on a distinguished road
picking out scrap steel ,any tips?
Guys know of any tricks for picking out scrap steel for machinability? mostly im using square bar stock
Other then a file to test the hardness. As of now i been just using the "hit and miss" approach.
Old 02-12-2005, 11:24 AM
HuFlungDung's Avatar
Moderator
What I do is make a little cardboard template with square holes in it. Then I go down to the junk yard and try to make everything fit. If it fits, and fills the hole, then "yup, its square"
That help?
Old 02-12-2005, 04:33 PM
nuplowboy is on a distinguished road
You've already covered my suggestion with the file. Beyond that, there's not a lot of easy was to test steel. You might get ahold of some small pieces of various grades (1010, 1018, 1040, 4140, etc) to get a feel for how the file does on each. I don't know if there would actually be much difference, but maybe. Short of fancy chemical analysis, hardness is about it. Maybe a hammer and punch could show more distinction between hard, sort of hard, and soft.
Old 02-12-2005, 07:35 PM
thanks guys
Old 02-13-2005, 03:31 AM
RotarySMP's Avatar
RotarySMP is on a distinguished road
There is also a grinder test. You look at the sparks to determine whether it is a low carbon building steel or a high carbon steel.
Regards,
Mark
www.wrathall.com
Drilling hardended steel - update DJ Morrow General Metalwork Discussion 3 11-29-2004 12:42 AM
why not steel? NeoMoses DIY-CNC Router Table Machines 15 09-11-2004 09:14 PM
