Old 02-11-2005, 02:35 PM
studysession is on a distinguished road
CNC Aluminum
Hi - I have a CNC Mill and I have been CNC'ing aluminum. I have a few questions...
Q1> Can aluminum be hardened like steel? I recently took a machining class and learned how to harden steel. But was thinking it might not work with aluminum. Wanted to be sure though.
Q2> Also - some items I see where people mill out a section of sluminum and place a piece of cut carbon fiber down into the aluminum for looks and to reduce over all weight. I want to do this with one of my projects but want to know what kind of glue or what is used to hold the carbon fiber onto the aluminum like that?
Thanks!!!
Please check out my CNC blog
http://cncinside.com
Old 02-11-2005, 02:55 PM
BigDaddyG is on a distinguished road
Studysession,
Aluminum can be anodized, which is a surface treatment only. The surface of the aluminum is all that gets hard, it works well for abrasion (rubbing) but not well for impact. The aluminum is porous and the surface with the help of and electrical charge is hardened.
Can't help with the carbon fiber, good luck.
Glen
Old 02-11-2005, 03:04 PM
I was thinking that would not be same as steel. I just wanted to be sure.
I am most curious on what kind of glue that will hold well - Keeping the carbon fiber peices that I cut onto the aluminum without it coming back off. Seems like anytime it gets cold, glue comes right off aluminum very easy.
Old 02-11-2005, 09:40 PM
ger21's Avatar
Use epoxy. West System sells an aluminum prep you use to get better adhesion. http://www.westsystem.com
Old 02-12-2005, 01:39 AM
NBrigode is on a distinguished road
I have had aluminum gears that I have made hard coated. If uses the same principle as anodizing, but is actually a coating of about .001. It seems to hold up quite well. The one thing that I have noticed is that the better finish the part is before hard coating or anodizing the better it will look afterwards.
Old 02-12-2005, 04:31 AM
Thanks for the replies - Is it hard to hard coat aluminum?
Old 02-12-2005, 09:39 AM
Gold Member
lerman is on a distinguished road
My understanding is that hardcoating is essentially the same as anodizing, but must be done at a lower temperature. Anodizing can be a DIY projetc. But, you would need some type of cooler to do hardcoating.
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Using your CNC Mill as a CNC Lathe lstool Knee Vertical Mills 10 08-02-2010 12:06 AM
Cheap CNC for maching aluminum debutis Parts for Radio Control Models 6 09-11-2004 04:38 PM
CNC Router cutting Aluminum 2Gs DIY-CNC Router Table Machines 7 08-09-2004 08:21 AM
milling aluminum with router(gentry) cnc setup camfambmw5 General Metal Working Machines 5 12-04-2003 10:31 AM
