Old 06-19-2009, 03:13 PM
klaymonster is on a distinguished road
Unhappy how small of a groove?
Is there really not a smaller grove you could make with cnc than with a 1mm bit? That is the smallest i've seen. Especially for plastic work it seems silly not to be able to make notches, grooves and holes smaller then that?!
Old 06-19-2009, 03:24 PM
scadvice is on a distinguished road
Smile
I'm not sure what type of machine you are referring to but.... Milling endmills go down to .010", off the shelf, slitting saws smaller yet. You can buy and grind a lathe tool thinner than 1 mm.
Steve
Old 06-19-2009, 04:06 PM
littlerob's Avatar
littlerob is on a distinguished road
www.kaisertool.com
Try this I think you are turning not milling right?
Old 06-19-2009, 05:23 PM
Oops i was being too vague.
on the contrary i am refering to mills/routers
there may likely be differences yet again between the two but i just cant further specify because i havent yet decided which i will be making my molds from, pastic or aluminum.
Its great to hear that they make them so small i wonder now can anyone direct me to a good supplier of endmills that small?
*EDIT* why did i look for hours last time with no luck and this time 1st google i've got my answer?! Jeeez seems to be plenty of suppliers matter of fact this one claims to have them down to .002"
http://www.microcutusa.com/decimal2flute.php
35 dollars each though ooouch!
Old 06-19-2009, 05:33 PM
Smile
Do a web for www.mscdirect.com lot of tools there.
Steve
Old 06-21-2009, 05:28 AM
rattus is on a distinguished road
Harvey Tool (www.harveytool.com) has 2-flute end mills down to 0.001"
Figure 8 Oil Groove penjas14 G-Code Programing 6 03-10-2009 01:25 PM
Newbie- Groove on O.D dpark1 Solidworks 1 07-31-2008 06:31 PM
O.D. Groove Stickmchn G-Code Programing 10 12-08-2007 05:29 PM
V-Groove Bearings widgitmaster DIY-CNC Router Table Machines 24 02-27-2007 03:14 PM
Q: Best way to cut small oring groove? Deviant General Metalwork Discussion 8 06-23-2005 02:38 PM
