Old 06-15-2009, 08:01 PM
diycnc is on a distinguished road
cheap belt and cnc
if one were to mount the encoder on the screw how important is the belt used in a belt reduction?
Old 06-17-2009, 08:09 PM
handlewanker is on a distinguished road
Toothed belt, short centre distance, not too narrow, and done up nice and tight.
Long belts are springy, and give you a form of backlash.
Motor must be firm fixed, not resilient mounted.
Ian.
Old 06-17-2009, 08:12 PM
i am using toothed belt on my build but wondering on if the encoder was after the belt drive what would be the problem with a tight v belt? wouldn't the drive compensate for slippage if the encoder is after the drive?
Old 06-17-2009, 09:09 PM
I'm a bit vague on that aspect of encoders etc, but as the encoder reads the position of the spindle, the before mechanism is irrelevant, just a driving force, correct me if I'm wrong.
Further down the line the screw has a nut and if it's bronze/Delrin etc on Acme thread, then you have a backlash problem to overcome, which doesn't occur if using ballscrews etc.
The toothed belt should be tensioned enough to prevent it from slipping over the teeth of the pulley, and in the case of automotive timing belts this is vital to keep the valve events happening at the right moment
Ian.
Old 06-19-2009, 08:15 PM
Davo J is on a distinguished road
I am building my 1st CNC Knee mill so i can not give you much advise but I have seen on the IH site they run the encoders on the lead screw there website states
(Mounting the encoder at the end of the ballscrew is more difficult that mounting directly on the motor, but it takes belt stretch and residual pulley buildup completely out of the equation).
In all my searching (around a year) have not really come accross much on the subject,I would still use a toothed belt as I think a V belt puts a lot more strain on motor bearing because of the amount of tension it needs.
Is it better to run the encoder directly on the lead screw as you are or on the motor were the encoder resolution is greater buy the gearing (eg 4 to 1).
Davo
Old 06-21-2009, 04:20 AM
Hi Davo, you'll also multiply all factors by 4, backlash, belt give, and any flex in the drive system.
Ian.
Old 06-21-2009, 06:29 AM
Ian thanks for that reply,is it comon (better)to run the encoder on the the end of the screw or on the motor shaft. I seem to see most people put them on the motor.I have bought slightly longer ballscrews than needed as I still dont know which way to go.Davo
Old 06-21-2009, 08:29 AM
i know on my project i have allowed my self to put the encoder on either the screw or the motor. i will see what works best.
X2 Timing Belt drive (cheap, of course!) blades Benchtop Machines 9 09-07-2011 03:48 AM
Need Sherline Belt & qestion on X2 Belt Drive? Oldboy Benchtop Machines 12 03-06-2008 01:42 AM
Belt size/spec for Sieg X3 driving belt rashid11 X3/SX3/G0619/G0463 0 02-10-2007 08:01 AM
Seeking Belt Sander Belt Source 6 x 48 Dugg General Metal Working Machines 3 12-24-2006 10:48 AM
