Old 06-15-2009, 12:19 AM
ranchak is on a distinguished road
Which insert to buy?
I have a face(spider) mill that uses SPMT inserts. I need to buy inserts but there are so many different types. I mainly will be milling aluminum, cast iron, mild steel and plastic. Whatever inserts that are in there work well, but there isn't any marking on them and I bought the mill used. Can anybody suggest some inserts that are responably priced?
Old 06-15-2009, 10:21 AM
PixMan is on a distinguished road
What company made the cutter, and what is the I.C. (inscribed circle) size fo the SPMT insert needed?
Old 06-15-2009, 10:37 AM
The cutter is made by Iscar, I don't know what the IC number is.
Old 06-15-2009, 10:40 AM
littlerob's Avatar
littlerob is on a distinguished road
try E-bay, but you'll need the ic, thickness and you'll need to know what chip breaker you want
Old 06-15-2009, 10:46 AM
You should be able to get some nomenclature off the cutter body. Those letters and numbers will tell exactly which inserts you need in terms of I.C and thickness. You will probably have to get Iscar inserts because more & more, the cutter manufacturer uses proprietary inserts for milling cutters.
An SPMT insert from Iscar may not be the same size as one from Kennametal. I know this is a problem with APKT inserts.
Tool Insert Help Cartierusm General Metal Working Machines 2 11-21-2007 09:05 AM
Mil-Tec Insert tools? John3 General Metalwork Discussion 5 09-23-2007 06:00 PM
Looking for Insert. Al_The_Man General Metalwork Discussion 10 08-02-2007 11:27 AM
Insert for 62 Hrc M-man General Metalwork Discussion 5 02-13-2007 04:09 PM
INsert Molding PC7 Moldmaking 3 04-15-2006 07:56 AM
