Old 06-04-2009, 09:48 PM
asctm is on a distinguished road
Punching 1080 wear plate
Running into trouble punching a 9/16 square hole over an existing 9/16 round hole in 1/2" 1080 wear plate. Does anyone has any good resources or links where I can get some info in trouble shooting this problem.
Old 06-07-2009, 11:10 AM
handlewanker is on a distinguished road
Hi I take it you get a square hole with some round indentation in one or more of the sides.
Possibly the hole was drilled 9/16", so the drill cut oversize, or you lined up the hole badly and the punch drifted to the side due to lack of support in the hole.
If the holes are already in the plate you've got problems, otherwise drill the holes to 17/32".
I've used a punch on a job like this before that had a small pilot on the end.
Ian.
Any tips for designing a fixture plate / tooling plate? thackman Benchtop Machines 9 12-19-2008 12:26 PM
Newbie- punching a program joehernandez Fanuc 9 09-24-2008 01:25 PM
CNC Turret punching? andy_ck87028 DIY-CNC Router Table Machines 0 02-08-2008 06:53 PM
Aluminum: flat, bar, sheet, plate, tooling plate?????????? Dan S DIY-CNC Router Table Machines 12 06-28-2007 01:48 AM
AR wear plate larry53 Mass finishing equipment/media/stratigies 0 04-19-2007 07:35 PM
