Old 06-03-2009, 06:45 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
Pipe threader questions
Hi all,
I'm looking at buying a pipe threader to make anchor bolts. There are alot of them to do, so it would be worthwhile buying a dedicated machine.
I've never used one before so I have a few questions.
1. Is it possible to setup the die head to cut slightly undersize threads? This is a requirement since the anchors will go for galvanizing after threading and bending.
2. What type of life can I expect out of the die head assuming the use of coolant and cutting plain carbon steel.
3. What type of tolerance is required for cutting a thread on a rod? Lets say the rod is oversized by .05", will the machine be able to deal with this?
4. What brands should I look at? I've been looking around the Ridgid site, since this is the only brand I know.
Thanks for your help.
Paul
gas pipe or hot/cold water pipe? jaymed2000 JGRO Router Table Design 2 03-15-2008 10:01 PM
Instead of Gas Pipe Bartsimsonii JGRO Router Table Design 3 11-19-2007 09:39 AM
emt conduit, galvanized pipe or black pipe? JohnG DIY-CNC Router Table Machines 5 05-21-2006 09:24 PM
Using Pipe Nightz DIY-CNC Router Table Machines 2 10-16-2005 07:07 PM
Black pipe questions ljoe1969 DIY-CNC Router Table Machines 20 02-21-2004 04:24 PM
