Old 06-03-2009, 05:09 PM
Geo88 is on a distinguished road
mitsubisi 520 axis revesal
Hi everyone
Was hoping someone might have some insight on a problem with a mighty comet mill i have, had a guy over to adjust my mill and he was doing backlash comp, when i went to use the mill to cut a radius when x & y start to interpolate the table jumps, i pulled the covers back and the the screws are reversing like it is rapiding i thought it might be the software so i wrote a 4" circle program by hand same thing could he have adjusted a wrong parameter?
Thankyou if anyone has any ideas
Old 06-03-2009, 05:29 PM
Al_The_Man's Avatar
The first thing to do is call the guy back to fix it!
Does it alarm out?
If not it is normal for an axis jump to occur when the axis take up back lash depending on what direction the compensation was in.
He may have applied too much as the servo is supposed to jump but not the actual table.
Old 06-03-2009, 08:01 PM
I set the backlash to the original settings myself i called him back he told me it was nothing he did and they would send another guy out but they were going to charge me again 100.00 travel time and 125.00 hr service time, things are slow for me i will have to figure it out myself, it does not alarm out but its jumping at least .150
Thankyou
Old 06-03-2009, 08:12 PM
Al_The_Man's Avatar
What happens if you set the backlash comp to 0? it should not jump if B.L. comp is the cause.
Old 06-05-2009, 10:50 AM
PixMan is on a distinguished road
What were the original settings (that you have put it back to) and what setting did the technician put in? Is the problem the same with both settings? As someone else also suggested, put the amount at zero to see if the problem goes away or is greatly reduced.
If not, you do have a different problem, but I suspect (as it seems you do too) that the technician disturbed something.
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 07:31 AM
New Machine Build- post for 2 axis ez trak versus 3 axis ez vision tooolman G-Code Programing 0 11-28-2008 04:33 PM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 08:15 PM
One axis (z-axis?) computer controlled testing device TsThorsell Stepper Motors and Drives 3 02-07-2008 01:38 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 03:58 PM
