Old 02-05-2005, 02:30 AM
h_2_o is on a distinguished road
Rotary Table Req
I've seen sites selling plans for an outragous price, i was curious if anyone here had plans for a 4" or so rotary table. one that looks semi-simple like this http://www.sherline.com/3700pg.htm doesn't look too difficult except for the gear inside it. I have access to a couple edm so that should help eliminate that problem. anyway if someone has something at a minimum it would be a neat learning experience.
Old 02-05-2005, 08:14 AM
Gold Member
JFettig is on a distinguished road
I have seen someone build a rotary table with a harmonic drive coupler, others with a wormgear drive, I dont have any links on me right now.
I recently bought the H/V rotary table from LMS and so far I am pretty satisfied. The reason I would say to buy one is that they are precision ground, parallel and acurate.
Jon
Old 02-05-2005, 11:40 AM
WayneHill's Avatar
WayneHill is on a distinguished road
Here is a link to a really simple 4th axis.
http://www.**********.com/4thaxis.htm
The ***** is "crank*organ" without the "*".
Some reason the link turned into *****. Maybe it is a band link web site ?
Old 02-05-2005, 01:08 PM
jfetting or anyone else for that matter, would precision grinding actually be needed if i was to use the edm to make the gears? and if not like i said the design of it would be cool as well to look at and learn from.
Old 02-05-2005, 02:05 PM
Gold Member
not grinding on the gears, but grinding to get the table parallel with the table of the mill and perpindicular, and to remove any runout.
I dont think it is necessary on the gears though.
Jon
Old 02-05-2005, 02:43 PM
ahhh gotcha now. yeah i can see where the table might cause some problems now that you say so.
Old 02-06-2005, 01:11 AM
ViperTX is on a distinguished road
Metal Lathe Accessories
Box 88
Pine Grove Mills, PA 16868
(814)234-3543
I welcome phone calls but if necessary email mlatoolbox@aol.com
These guys have some a nice rotary table and other accessories...you always see them in Home Shop Machinist. I've never bought from them, but their articles are always very good.
Old 02-08-2005, 02:53 AM
viper: thanks for the info, however it really wasn't about purchasing one, but more along the lines of the process and design of one. that's why i was looking for plans, never hurts to learn
Old 02-08-2005, 10:59 AM
MLA actually has kits that you machine the pieces to get the final product. Generally the big pieces are made of cast iron. So, if you want to learn it's a great way to kick off the process.
Old 02-08-2005, 01:11 PM
wouldn't really want a kit, i'd still rather have a design. except for precision grinding on the table and the plans i readily have available to me everything needed.
Advise needed for rotary table conversion spoiledbrat DIY-CNC Router Table Machines 2 05-11-2005 02:34 PM
Build a CNC rotary table? (longish) jcolley Mechanical Calculations/Engineering Design 0 02-12-2005 08:23 AM
rotary table chuck senor J. General Metalwork Discussion 2 12-15-2004 03:21 AM
5th even 6th axis? how does it work ToMMY2ooo General Metal Working Machines 10 10-04-2004 03:58 PM
Cross slide work pc on rotary table replicapro General Metalwork Discussion 4 07-08-2004 05:30 AM
