Old 05-20-2009, 10:22 AM
littlerob's Avatar
littlerob is on a distinguished road
TAPPING PROBLEMS
Hello all, I am tapping blind holes in 304 SS using an M12/1.75 spiral flute, coated tap at 1000 RPM, using a letter Y drill, my problem is the material is galding BEHIND the flutes, after about 20 parts with a single hole, coolant is at about 14 percent. Thanks in advance.
Robert
Old 05-20-2009, 11:21 AM
HuFlungDung's Avatar
Moderator
Try a real tapping fluid.
Old 05-20-2009, 11:37 AM
littlerob's Avatar
I think I got it, I was hesitant about using a cold forming tap in 304 but I was to a point I didn't have much in the way of options. It is working ok so far we'll see how the day progresses. Thanks Hu.
Robert
Help with tapping problems - breaking taps shorton General Metalwork Discussion 5 04-12-2009 01:08 PM
Newbie- Rigid Tapping Problems crazycnc Fanuc 12 06-09-2008 06:39 PM
Haas TM-1P Rigid tapping problems dapoopta Haas Mills 3 03-18-2008 08:39 PM
Problems with tapping head. Chuck Reamer Tormach PCNC 4 11-12-2007 09:16 AM
Problems tapping an acme nut js530 DIY-CNC Router Table Machines 8 05-21-2005 07:52 AM
