Old 05-18-2009, 11:01 AM
fridayc is on a distinguished road
Can't identify quick-change spindle
Hello. This is my first post although I have enjoyed the forums and gallery for awhile. I am in the process of accumulating parts to build a CNC machine. I recently purchased a couple of what look to be quick-change spindles that I would like to use for a light to medium-duty CNC machine. On the tool end each one has a taper and an internal female thread. The major diameter of the taper is .600" and the minor diameter is .500" with a 3/8"-24 internal female thread starting .60" in from the major diameter. There is also a spring loaded cover and a nylon sleeve with ball bearings that the cover rides on. The bearings are small and don't protrude into the tool holding area. These spindles are 3" outside diameter with a 7/8" shaft. I've included links to some pictures. Does anyone recognize the configuration? TIA
http://cgi.ebay.com/ws/eBayISAPI.dll...ayphotohosting
Build Thread- $35 Dollar X2 Quick Change Regnar Benchtop Machines 13 03-16-2009 01:20 PM
Quick Change Gear Box larry53 Want To Buy...Need help! 0 05-10-2008 01:23 PM
quick change R-8? replicapro Benchtop Machines 10 04-14-2006 10:00 AM
Quick change router bit wjbzone DIY-CNC Router Table Machines 13 06-07-2005 12:56 PM
R8 Quick-change recommendations Swede General Metal Working Machines 4 04-16-2004 09:59 AM
