Old 05-17-2009, 11:25 PM
RP Designs is on a distinguished road
It is here!
After nearly a month, and loads of heartache it is here in all its 4500 lbs of glory. More to come...
Old 05-19-2009, 10:36 AM
I have been looking for a CNC knee mill to retrofit for quite a while and after reading other peoples project logs I started to look for a machine worth doing the retrofit on. Cost was a huge consideration because many of the machines I was looking at where prohibitively expensive. I searched craigslist, ebay and machinery resellers and kept coming up short. I was becoming quite frustrated because I couln't find any of these great bargain machines. Then a mill came up on ebay for under a grand and it wasn't across the country. I picket up a comet model #1630 off ebay for $750 with a dead fanuc control. It cost me another $880 to get it up to me so right now I am into it a little over $1600 and have a pretty decent machine with large travels (30x16), a 3HP motor, power drawbar and a host of other little goodies. Machine also came with the manuals some tooling and a few miscellaneous bits.
Getting this thing home proved to be a bit of a PIA with two very flakey movers and about a month of aggrevation. I had to remove the motor and the power drawbar to get the thing in the garage but it fit, so that is done. I now have a large cleaning job ahead of me seeing how the previous owner left it covered in chips.
I am now in the planning stages of the retrofit. I am most likely going to go with a kit (Ajax CNC or equivalent) for the ease of install and just to have someone to contact in case of problems. This will be my first retrofit so I would like to minimize the learning curve if possible. Right now the machine is outfitted with a Fanuc 10 control. The servos are Fanuc 0m on the Z axis and 5m on the x and y axis. Speed control is done with an induction motor which controls the variable speed drive. What I want to do is convert the drive to a VFD for two reasons, first I don't have 3-phase power and I would like to try and increase the spindle speed even if only by a small amount. I would also like to add an encoder to the spindle for rigid tapping. I will be replacing the velocity drives with encoders and plan to add a 4th axis in the near future.
Now if I can't get the retrofit kit like I want I will begin to assemble it myself. I would love to hear from other people as to which vendors they use, which products they like and who to avoid. I want to keep the experimentation to a minimum and would rather rely on other's experiences and go with proven products.
