Old 05-11-2009, 06:09 PM
pweber6327's Avatar
pweber6327 is on a distinguished road
Unhappy OD Grinding Stainless Steel
Any tips or helpful info on OD grinding stainless steel would be appreciated.
We are trying to grind a 6' diameter stainless steel drum using a Dumore tool post grinder and a 12" diameter wheel. Speed and feeds for doing this would help alot.
Using a silicon carbide (green) wheel.
We are not OD grinders by trade so any help in this area would be greatly appreciated.
Old 05-12-2009, 04:06 PM
How thick are the walls of the drum? Do you get harmonic vibration/chatter? Do you have access to the inside (put liquid inside)?
In another life we had a crew that ground 15' dia. cast iron dryer drums while installed in paper machines. Used traversing belt grinder rig for those.
Also ground thin walled chill rolls back in the shop.
I have no idea what your set-up is. Can you 'splain?
Dick Z
DZASTR
Old 05-12-2009, 04:37 PM
pweber6327's Avatar
Here's the rest of the story
The walls on this tank are made of 317 stainless and are perforated with 9/16" holes, the holes spacing is quit close. The drum contains 17,478 holes. The shell is welded with Inconel. Vibration does not seem to be an issues.
By the way the walls are 1/4" thick.
It was suggested to me that we use a Silicon Carbide wheel.
Thanks for the help...
Pat
Old 05-12-2009, 06:09 PM
Pat, the wheel manufacturer is probably your best source for application info. Surface finish requirement, Coolant etc. will be required.
I've used a grinding attachment on a VTL, worked fine. A large dedicated vertical grinder would be ideal but not always available.
How long is the workpiece?
Dick Z
add: Be careful on the coolant. Some coolants can soften the bond, particularly the old style resin or shellac bonded green wheels.
DZASTR
Old 05-12-2009, 06:15 PM
pweber6327's Avatar
The drum is 6' long, once we get a little water under our feet with this type of grinding we will be able to market this as a service to our customers.
Pat
Old 05-13-2009, 07:26 AM
What does the machine you grind on look like? Picture?
Dick Z
add: I see on your personal info your located at Escanaba. I'm in the Milwaukee area.
DZASTR
Stainless Steel jdclark Shopmaster/Shoptask 2 02-24-2009 10:08 PM
Stainless for hardening and grinding? DennisCNC General Metalwork Discussion 1 03-30-2008 06:32 PM
Stainless steel larry53 General Metalwork Discussion 4 04-22-2007 11:32 PM
Steel or Stainless tool_man Casting Metals 2 10-29-2006 05:46 AM
Stainless Steel ? Depoman General Metalwork Discussion 2 01-12-2005 05:40 AM
