Old 05-09-2009, 12:45 PM
tjhj's Avatar
tjhj is on a distinguished road
To Ball-screw or Acme?
Hello All,
Thank you for taking the time to read this and to help if you do.
I am a new owner of a HF Mini Mill, and am much better with electronics than mechanical things so I purchased this unit with the intent of converting it to CNC operation.
I decided that because this is my first CNC machine build I would be better going with a pre built kit instead of making my own, and maybe the next one I will build from scratch, but this is where I have found an issue.
The two kits I have been considering are the CNC kit from Little Machine Shop.
http://littlemachineshop.com/product...ory=1687114045
And the ball screw kit from CNCFusion. Kit #4.
http://www.cncfusion.com/minimill1.html
I have been reading everything I can find and talking to everyone who will talk to me, and the general response I get always is Ball Screws have less backlash.
Now the big question price aside are ball screws really that much better?
There has to be a disadvantage to the use of ball screws or why doesn't everyone use ball screw kits?
Is the backlash reduction more consistent with a ball screw over a proper Acme thread with anti backlash nut?
Will this choice affect my ability to hand operate the machine, for quick touch up/ ect work?
One person told me that ball screws are more sensitive to cleanliness and can more easily become damaged by trash getting in/on them. Is this true? Or a major consideration?
I was also told that ball screws are less used due to their cost, in a manufacturing environment I can understand the cost of acme screws being advantageous a few dollars over thousands of units adds up. Is this where the choice stems from?
Am I over thinking this?
Thank you for your time and any help or advice you can share.
TJ
EDIT : I hope this is the correct forum, I thought this was more of a general question than a machine specific question.
Old 05-09-2009, 12:49 PM
Is your Nema? screw anything like an ACME screw?
Dick Z
DZASTR
Old 05-09-2009, 12:52 PM
tjhj's Avatar
Doah sorry Ive got Nema on the brain this morning... Ill fix that. I meant acme.
Old 05-16-2009, 11:12 AM
John Welden is on a distinguished road
Go with the ball screws for sure. The only good reason not to go with them is if you can't afford the cost.
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
roller screw versus ball screw. Paraprop Linear and Rotary Motion 2 04-15-2007 04:21 AM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 12:10 AM
