Old 05-07-2009, 12:57 PM
RP Designs is on a distinguished road
Increasing spindle speed
I am still in the planning stages of my retrofit (still waiting for the machine to arrive) and know I will need to either get a phase converter or VFD. I will most likely go the VFD route because I can also use it to increase the spindle speed. Everything I have read says I can push the VFD to double the frequency, or 120hz, which will effectively double my spindle speed. My spindles current max RPM is 4200 RPM so I could theoretically push it to 8400 RPM. But this is an older large (4500lb) knee mill and I am concerned how much speed the actual spindle can handle. At what point (RPM) do I worry that the bearings can't handle the speed? When do I need to add bearing coolers? What about spindle balance, tool issues or anything I am not thinking about? Am I being too ambitious in trying to push a spindle designed around 4200 RPM to double that?
Spindle speed not 100% AndyB Fadal 6 07-13-2007 08:52 PM
Spindle Speed teenrocketnerd DIY-CNC Router Table Machines 1 06-20-2007 05:59 PM
increasing spindle bore on 9x20 Runner4404spd Mini Lathe 5 03-05-2007 12:08 AM
Spindle Speed wildcat Industrial Hobbies (Support forum) 4 01-27-2007 10:40 PM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 03:29 AM
