Old 04-30-2009, 04:56 PM
cncdoctor is on a distinguished road
Exclamation XYZ 560 Mini Mill Fault
Can anyone please help!!
A friend of mine has a XYZ 560 Mini Mill. The machine shows the following fault message: -
Profibus-DP Fault on drive Y
Code 504 value 0
Acm No 380500
The fault is intermittent and we cannot find the fault. The motor, encoder & the connections between them have been checked. The drive for that axis has been swapped i.e. X-axis drive has been swapped with Y-axis drive but the fault still occurs on the same axis.
Has anybody suffered with the same problem?
Does anybody know what the cause is?
Last edited by cncdoctor; 05-02-2009 at 12:29 PM. Reason: Details had been forgotten
Tags
xyz 560 mini mill
Mini lathe and mini mill spindle? ZipSnipe General Metal Working Machines 3 10-15-2010 08:13 AM
Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head fignoggle Benchtop Machines 18 05-11-2009 11:11 PM
Coming Down to the Taig Micro Mill or Grizzly Mini Mill. SpeedsCustom Taig Mills & Lathes 15 01-22-2009 11:14 PM
X2 Mini Mill & Mini Lathe - Cummins Tools ccsparky Benchtop Machines 0 12-19-2007 07:54 AM
Prototrak mill axis fault AtomicBeaker General Metal Working Machines 1 06-23-2006 12:52 PM
