Old 04-30-2009, 12:10 PM
GM81 is on a distinguished road
Femco Durga-25E Tool Change Issue
I have posted for help with this machine before and received some great feedback, so once again, I am here for some wisdom.
At random times, a tool change cycle won't work, the machine just hangs and I have to reset the program and cross my fingers it will work when I try to start the program again. However when in Handel I can change both turrets and they function fine. On thing that struck me as off is when I cycle through both turrets, if I go from turret 2 to 1, turret one will spin backwards for one tool location before spinning the right way, but if I just use turret 1, it will start off spinning the right way. I have no idea if this is relevant, but i figure more info is better than not enough.
Anyone have these troubles before? Thanks in advance for any input.
-Garrett
Old 10-16-2009, 12:57 PM
saul is on a distinguished road
Unhappy i have the same problem
do you have any solution for that
thaks
Old 01-22-2010, 05:29 AM
chich2 is on a distinguished road
On a Femco Durga 25-E I believe to index turret 1, Turret 2 must be in tool 25 position.
To index turret 2, Turret 1 must be in tool 1 position.
Chich
Femco Durga 25-E Service Tech Billet Sean General Metal Working Machines 8 10-17-2010 01:57 PM
Need Help!- FEMCO DURGA 25E destinationmx General Metal Working Machines 2 11-24-2008 06:00 PM
Femco Durga 25-E Billet Sean General Metal Working Machines 0 06-25-2007 08:00 AM
Fanuc tool change homing issue openforbiz Fanuc 8 01-31-2007 02:35 PM
