Old 04-28-2009, 02:31 PM
pmurdock is on a distinguished road
t-nuts on 3 jaw have huge effect?
Anybody have have t-nuts on a hydraulic power chuck (kitagawa B210) cause serious runout? I thought the t-nut's were there to hold in the jaws and the serrations are meant to line things up.
I had a 5C collet system for my 3 jaw that had run out of .010" or so - master jaw system from usshoptools.
I tried everything - i took apart the 3jaw chuck, i honed all the surfaces to clean them. I checked the spindle adapater, the spindle, etc.. and in the end all I had to do was change out the t-nut's on the jaws.
am i crazy - or is this common with t-nuts?
cheers,
Paul
Old 04-28-2009, 08:32 PM
HuFlungDung's Avatar
Moderator
That is a strange one. Maybe screw a long straight dowel into the t nuts and see if one of them got tapped crooked. Another thing to check would be the parallelism of the bottom of the counterbores in the bolt on jaws, and see if one of those is deformed. Easiest way I can think of doing that is with a dial indicator sliding around on a surface plate with the jaw sitting on the plate.
Old 04-29-2009, 09:26 AM
the strange part is up until about 3 weeks ago - the original t-nuts were working fine. we then had a drawbar issue with it coming lose from the spindle - we retightened the drawbar to he spindle and ever since those t-nut's were causing run-out.. strange, strange, strange.
cheers,
Paul
Old 04-29-2009, 01:03 PM
big_mak is on a distinguished road
Was there perhaps an unreported Run into the Jaws?
IF I recall the t nuts fit quite nicely in the master jaws, so if your jaw is off to one side, this may cause the run out!!!!
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
Old 04-29-2009, 03:02 PM
Considering I'm the mail room, ceo, shop foreman, only machinist, and cafeteria server I'm certain there wasn't an unreported run in.. unless I did something bad..
joking aside - it's strange because visually the t-nut's look ok.. no serious damage looks to have occurred to those t-nut's..
boggles the mind!
cheers,
Paul
Acrylic got hairline effect supremeindex Glass, Plastic and Stone 0 02-06-2009 04:35 AM
What am I getting this effect?... cnczoner General Metalwork Discussion 33 02-01-2008 11:31 PM
Hall Effect Chopper legomanww General Electronics Discussion 5 12-20-2007 02:11 AM
guitar effect xfidelity Hobby Discussion 0 06-26-2007 06:19 AM
Cycle pause in effect? What? wildcat Mach Software (ArtSoft software) 0 12-02-2006 05:28 AM
