Old 04-28-2009, 02:10 PM
zaebis is on a distinguished road
HSS vs Carbide for milling
I am new so was wondering for cutting (milling) aluminum at my mill's max 3600 rpm will carbide pins be of any use at all? I hear they need to be 2 -3 x the speed of comparable HSS, so well over 3600 max rpm I have available. I have mostly prototype work, no mass production. Will I be able to take any advantage of carbide pins for feed speed at lower spindel rpms? Do carbide pins give me any edge?
p.s. I also plan on cutting steel and stainless.
Old 04-28-2009, 10:17 PM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
What is a "carbide pin"? Did you mean endmill?
As far as carbide on aluminum with a lower RPM spindle such as you have, your only REAL advantage is going to be less tool flex with carbide. HSS tools can flex quite a bit and leave scallops that carbide will be much less likely to leave.
As far as steel and stainless, carbide is highly reccomended. Carbide has higher working temps and less flex which will allow you to increase your feeds/speeds, DOC and axial step over, as well as IPT. Even with a 3600 RPM spindle, you'll see night and day differances on steel and SS.
MC
Old 04-28-2009, 10:39 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
in general carbide is your best bet , but on the other hand hss has it's own advantages as well , usually hss works well on sloppy machines or sloppy fixturing , the tool will flex rather than chip or snap as a carbide would , carbide tooling prefers rigidity and it won't flex , also cost efficiency can be a factor as well , for someone new and starting out
hss is much cheaper in price and may be a good option to use for experimenting and getting a feel for the machine , a few broken hss endmills is a fraction of the cost of carbides and it won't hurt the pocket book as badly
In the past I have generally prefered hss on soft plastics because they had been sharper than carbides but with the improvements in carbide , the carbides are now much sharper than before
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 05-02-2009, 04:08 PM
Billiam is on a distinguished road
Is this for a bridgeport? You may not have the spindle hp to take advantage of carbide.
Old 05-06-2009, 01:45 AM
crabbass is on a distinguished road
I would cry if i didn't have carbide tooling for my bridgeport knee-mill. Especially on larger tools (face mill's). Like dertsap pointed out, some carbide end mill's arn't as sharp as cobalt or HSS mills. Pressed carbide inserts actually have a small honed edge (like a .001"-.002" chamfer) and you can see the results in the finish on aluminum and plastics. I usually only resort to HSS or cobalt when the setup is loose, such as line boring, portable mills, and extremely abusive interupted cuts.
Need Help!- Chromium Carbide mashteuiash CNC Plasma and Waterjet Machines 2 03-19-2009 07:12 AM
Carbide conundrum derekBPcnc Bridgeport and Hardinge Mills 12 10-06-2008 08:23 AM
HSS VS Carbide Heavy D General Material Machining Solutions 12 01-31-2007 12:40 AM
carbide drills MBG General Metalwork Discussion 30 10-23-2005 08:03 AM
Drilling INTO carbide runnoahrun Hard and High Speed Machining 11 02-09-2005 02:33 PM
