Old 04-25-2009, 09:22 PM
farmboy is on a distinguished road
Centering square stock with a 4-jaw chuck
Hello All,
This is a great site. About a mount ago I jumed in and bought a Sherline lathe and I was wondering how would you center a square stock in 4-jaw chuck? I've managed to center round stock using a dial indicator, given enough time , so how about square stock.
Thanks.
Pete
Old 04-25-2009, 09:43 PM
ViperTX is on a distinguished road
The process is basically the same with the exception of having 4 faces.
A shortcut would be to scribe diagonally across the end of the stock to mark the center of the stock...then have only a short piece of stock sticking out of the 4 jaw....run your tailstock with a sharp pointed center...and use the center of the marked stock to align with the tailstock center....that should dial you into a range that you can fine tune.
Paul
Old 04-25-2009, 10:09 PM
Superman's Avatar
Superman is on a distinguished road
Clocking up round stock is a lot easier than square or retangular, but the principle is the same, the opposite face should be equi-distant from the centre.
Most may use the tool point as a rough centering guide, other have a scriber mounted on a post sitting on a plate crossing the slideways
If high accuracy is required, use a dial indicator ( not a lever type) mounted on the tool-turret, zero on lowest point on one face, wind out, rotate spindle 180 degrees, wind in ( while finding the lowest point ) and centre the part,
Repeat for the other jaw pair.
Don't forget to recheck all faces before final tightening
If doing off-center work, a good practice is to mark-out your first piece, and center on the marked out point. Remember to counter-balance your chuck to stop vibrations at higher RPMs.
( A little trick is to centre punch stock centre, use a pointed 1/2" shaft, 4" long with a centre in it's bum, mount this between tailstock centre and your centre mark, and clock zero nearest the stock )
EDIT: boy, you've got to be quick, very similar to ViperTX
Old 04-26-2009, 12:06 AM
Thanks. I'll give it a try with the dial indiactor.
Pete
Newbie- Centering flat stock in 4 jaw chuck daanmuller General Metalwork Discussion 9 04-22-2009 05:33 AM
Radius on the corner of square stock ErnieD General Metalwork Discussion 5 03-30-2008 09:35 PM
Need Help!- Need help with Set-Tru chuck centering dpseafish General Metalwork Discussion 10 03-16-2008 07:14 PM
Centering Chuck shadowdog500 Mini Lathe 13 12-02-2007 05:25 PM
Centering a 4-Jaw chuck gdl357 Mini Lathe 10 09-20-2004 05:24 PM
