Old 04-17-2009, 12:16 PM
750iow is on a distinguished road
heidenhain sub program variables help?
Right. im on a gildemiester dmg ctx 400 with heidenhain eltropilot 3190 control.
when writing a sub program, when controling the variables you use the
IF
THEN
ELSE
ENDIF
is there a list of words which you can use in the sub program. because i am haveing trouble changing a parting off cycle i need a sort of repeat untill, or a rounding function to round up numbers. but i have no idea what word or functions will work inside DIN plus. any help on this subject would be great.
ps im not sure if i have put this in the right place or not.
thanks.
Need Help!- HEIDENHAIN q def program spennyy2k General CNC (Mill and Lathe) Control Software (NC) 0 02-18-2009 12:48 PM
Series I with Heidenhain 155 Won't run program dbcooper99 Bridgeport and Hardinge Mills 13 10-16-2007 01:56 PM
Possible to write variables to a program? Heavy D G-Code Programing 2 08-21-2006 11:08 PM
Sinumerik program variables on screen cosmikdebris G-Code Programing 0 03-17-2006 07:55 AM
Use of user cycles and variables in a techology program Grom1 DeskCNC Controller Board 0 09-27-2005 02:18 AM
