Old 04-16-2009, 11:56 AM
milehighxr is on a distinguished road
Question What high speed spindle machine
Should I look at? What should I avoid? I am looking for a 3(possibly 4/5)axis machine with the following traits:
1. 25k-100k RPM spindle(ok 100k is unrealistic I'm sure)
2. CAT 40 spindle
3. 40x20 inch work envelope(minimum)
4. Must be sealed against abrasive dust like a graphite machine, but still capable of cutting at the least AL, preferably all metals)
The plan is to machine composites, pre-pregs, and even AL on it. I'd to be able to use it for other metals too, so that if the jobs it is purchased for disappear we can reconfigure for other things. This for the production job shop I work in, so it has to be something that will last. I'd like to know who's machines are the best for this kind of stuff, and who to avoid because of all kinds of problems. This is the first time I have been tasked with researching machinery, so any help would be appreciated.
Mods, if this is the wrong forum feel free to move it...
Old 04-16-2009, 10:04 PM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
Your not going to get a CAT40 spindle in 25K, they really shouldn't go over 10K, they make them up to 15K. Your probably going to end up with HSK tooling, or similar.
They have made 100K, I rebuilt a couple of 80K personally, but they are rare. I've never seen a 100K in service, but I know the company I used to work for made a couple for specialty machines, servo driven, not air driven.
What ever you end up with is going to be quite an investment. Biggest thing is make sure you can get service when needed. And don't crash! 25K plus RPM spindles are pretty touchy, doesn't take much, the bearings are delicate.
MC
Old 04-16-2009, 10:11 PM
TOTALLYRC is on a distinguished road
High speed machine
I like the look of these and they make a version for graphite work to handle the abrasive dust.
http://www.highspeedcnc.com/index.htm
I would have bought one if I could have afforded it, but my budget was off by 95% of the cost.
Mike
Old 04-17-2009, 07:09 AM
Thanks guys, research continues. It looks like 25k will be the fastest I can find.If it can't hold a 3/4 end mill, or a face mill, I don't want it. It will be too specialized, and too small of a work area. I'm looking for something similar to: http://www.dmscncrouters.com/
Old 04-18-2009, 05:34 AM
I don't think that would be a good machine for aluminum, doesn't look nearly ridgid enough. Did you notice in the video, they were cutting plastic, or something very soft and flexable.
Old 04-18-2009, 08:16 AM
The machine I have now, is a Hurco BMC 4020. I think I can retrofit a highseped spindle to that. Highly specialized equipment is not in the future-yet...
Old 04-18-2009, 09:43 AM
A spindle speeder or auxilery spindle would probalby serve you well.
Mike
Old 04-18-2009, 01:16 PM
the spindle speeders work well, probelm is I can't hold any cutter bigger than .250"...
Old 04-18-2009, 02:25 PM
use the spindle speeder for the small tooling and then use the standard tooling for the bigger stuff.
The spindle speeder will in most cases even fit tin the tool changer so it would be just like any other tool.
Mike
Old 04-25-2009, 12:46 AM
John Welden is on a distinguished road
I don't see why you'd need a zillion RPM's to cut composites?
High RPM machining isn't something you want to do if you don't have to.
  #11   Ban this user!
Old 05-10-2010, 07:45 AM
DaveJ-FTM is on a distinguished road
I don't know if you have thought of this but keep in mind that in order to utilize the higher RPM's, the machine also will need to have enough "smarts" to accurately keep up with the programmed path. Depending on the complexity of the geometry and tolerance, this may or may not be a serious issue. There are many machines, controls, and high speed options out there and just because a machine can run 25K or more doesn't mean it will do you want it to do. Anyway, this is just some food for thought. Good luck.
dj
Add DIY high speed spindle? bseibenick General Metal Working Machines 11 12-08-2009 09:35 AM
VFD help for high speed spindle juzwuz Phase Converters and VFD 4 03-21-2009 08:27 AM
X3 high speed spindle project5k Benchtop Machines 68 03-10-2009 01:14 PM
High speed air spindle pebbert General Metalwork Discussion 3 11-08-2008 02:25 PM
High speed spindle... how high? jonesja2 General Metal Working Machines 0 06-04-2007 07:18 PM
