Old 04-16-2009, 11:36 AM
rlmomc is on a distinguished road
Wink New Controls
Hello all.
Thanks again to you for helping me with my Bridgeport EZ trak.
Been running great.
I have a question now on a totally different machine.
I have a Sharnoa SD-850 3 axis CNC with Tiger 3 Controls.
It's a 1985 machine. Good iron, and still holds tolerances of +/-.001 over
the entire xyz. The only limitation is 6" Z travel, but heck I don't mind.
It also uses a paper tape to load the master program plus cam cycles, letter engraving, and Mold program. Sooner or later that reader is gonna fail.
I've been extremely lucky thus far.
So the question. What can you all recommend as far as replacing Tiger 3 controls? The drivers, rotary encoders, belts etc are in great working order.
PC based seems to be what I see here. (even though I have always used a Mac) So any suggestions? or what to avoid?
Thanks in advance once again.
Old 04-16-2009, 12:45 PM
TOTALLYRC is on a distinguished road
Originally Posted by rlmomc View Post
Hello all.
Been running great.
What voltage are the motors?
Do you have analog input +-10v drives?
If the drive voltage is over 100v or so and the drives are good and analog input, try the DSPMC/ip from Vital systems.
I am using it on my mill and I am putting it on my lathe conversion as I type. I find it tough to type with wire strippers in my hand. LOL
See my build log for more info.
http://www.cnczone.com/forums/showthread.php?t=66994
Mike
PC Controls vs. Industrial Controls Billiam General CNC (Mill and Lathe) Control Software (NC) 0 03-16-2009 08:54 AM
Cincinnati Controls kool-aid13 General Metal Working Machines 1 05-25-2008 01:08 AM
Jog Controls dafowfidy Mach Mill 2 03-21-2007 04:01 PM
Controls Chuck Pool General CNC (Mill and Lathe) Control Software (NC) 7 02-23-2006 11:49 AM
API Controls software Stevie Servo Motors and Drives 2 12-01-2005 05:27 AM
