Old 01-15-2005, 03:29 PM
Willyb is on a distinguished road
Spindle Grease ?
Hi guys
I would like to re-pack the spindle bearings for my CNC Milling machine before putting it to work. It has a double set of Tapered Roller Bearings and spins to a maximum speed of 3,000 rpm’s. Any idea of the best grease for this application?
Thanks for the help.
Bill
Old 02-14-2005, 07:32 AM
*Registered User*
Per_N is on a distinguished road
Kluber Isoflex NBU15
Don't put in to much grease beacuse the bearings will go hot. Usually no more then 30% of the free area should be filled with grase. Check your bearing data.
Old 02-14-2005, 01:44 PM
steveg is on a distinguished road
Kluber EP8 is the grease that I have encounted being
used on roller bearing
NBU15 is definatley the way to go with balls
Old 02-14-2005, 03:46 PM
Kluber Grease.
Hi Steveg & Per_N
Thanks for the help with my question on Spindle Grease applications. Have either of you guys purchased this Grease? Any idea were I could purchase this product? I have sent an email to the company asking for more information. I will let you know when I get a reply.
Regards
Bill
Old 02-14-2005, 11:57 PM
*Registered User*
Just do a search on the Google and you will find lots of hits.
Regards Per
Old 02-15-2005, 05:50 AM
willy we bought ours from Stork Canada in montreal
they have it in "toothpaste" tubes, greasegun cartridges
and 1kg cans as well as large contains for those that need it
the tube, 100ml (if I recall correctly) is more than enough to do
several spindles. as Per says you don't need much per roller.
It's been almost 5 years since i've worked at the MT dealer so I
don't know if stork still carries it
Storks phone#1 450 6596571
www.kluberna.com Kluber is the grease that perhaps the vast
majority of machinery builders use certainly the Japanese
Old 02-15-2005, 06:10 AM
did a bit of searching looks like ep8 disappeared
(or was a figment of my failing mind )
look here http://www.klueber.com/Anwendungen/K...startframe.htm
for the recommended taper bearing grease.
turns out that you want ISOFLEX LDS 18 SPECIAL A
Old 02-15-2005, 03:25 PM
Spin Doctor is on a distinguished road
Barden sells NBU 15 under the part number G46. It is available in 30cc syringes. Another Kluber gease thety handle is Isocanol under the G75 part number. It should be available from a local bearing supply house that handles precision ball and tapered roller bearing. 3000 RPM sounds a little high for tapered rollers
Sherline spindle to 30k RPM -- am I crazy? nicad General Metal Working Machines 21 11-17-2010 02:57 PM
Grease in my THK bearings/carriages samualt DIY-CNC Router Table Machines 17 07-06-2008 10:44 PM
Gilman box spindle pics Swede Benchtop Machines 5 03-30-2005 09:41 AM
2.2KW Allen Brad. Spindle motor? GalaticDan Servo Motors and Drives 2 02-02-2005 11:46 AM
grease for bearings georgebarr General Metal Working Machines 5 02-16-2004 08:54 AM
