Old 04-14-2009, 09:18 AM
lager1978 is on a distinguished road
Threading D2 material
I'm realitivly new to CNC machining and I need to know if anyone can help me with threading 1/2-13 holes in D2 material? Your help will be greatly appreciated.
Old 04-14-2009, 11:42 AM
One of Many is on a distinguished road
If it is in its raw annealed state, that should not be much different that mild steel. Use a 27/64th drill and go at it.
If it is hardened above 48, it becomes near impossible with standard HSS taps.
Annealing D2 is a long drawn process you might want to send out to have done.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 04-16-2009, 01:56 PM
juergenwt is on a distinguished road
D-2 as purchased (not heat treated)
HSS plain - Vc = 5-10 m/min
HSS TIN - Vc = 10-15 m/min
HSS TiCN - Vc = 12-16 m/min
LUBRICATION : Emulsion deluted soluble oil 10% to 12%
or: Cutting oil with special additives.
This is about 50% of the speed used to tap 1018.
Preferred tap would be a tap with interrupted teeth, Chamfer form C (2-3 threads).
This would be for a thru-hole.
ID Threading Toddjones G-Code Programing 6 05-24-2009 12:46 PM
C6 Threading. ToolMach_Aust Syil Products 9 08-01-2008 03:52 PM
NPT threading cam1 General Metalwork Discussion 0 03-04-2008 07:55 PM
G76 threading mcm1961 General Metalwork Discussion 1 02-13-2008 05:36 PM
CNC Threading cncuser1 Mini Lathe 8 03-21-2006 07:43 PM
