Old 04-12-2009, 06:28 PM
speedrider is on a distinguished road
mazak communication trouble
I am having a problem sending a program from the computer to machine. The machine is a Mazak VTC-16 with M32B. The program goes from machine to computer, but not the other way.
Trying to go from computer to machine gives me a 553 error.
I am using a null modem cable with settings of even parity 2 stop bits 8 data bits and 4800 baud on both ends. I tried 8 on machine and 7 on computer and it still won't go.
Anyone know what I might be doing wrong?
This cable works great on my Haas machines.
Old 04-18-2009, 11:35 PM
crabbass is on a distinguished road
If you can send a pgm from machine to comp. I think you have all your settings fine (maybee not optimized). Try creating a eia program on the machine and sending it to your pc. Look at the file name and extension as the mazak outputs it. (I think you are trying to send a file with an incorrect extension or filename.) delete the program off your machine and try to send it back to the machine from your computer.
Are you using EIA/ISO (g-code) or mazatrol?
hope this helps, I once had a similar issue with a vtc16 with pcfusion
Old 04-19-2009, 06:40 AM
I did all exactly as you said, and still got the 553.
Need help with communication. AceikTool EDM Machines 4 09-30-2008 01:33 AM
Need Help!- Mazak QT-10 T2 manuals --acct w/ mazak? CDTINC Mazak, Mitsubishi, Mazatrol 0 06-30-2008 08:42 AM
Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem sting_dot Mazak, Mitsubishi, Mazatrol 0 05-21-2007 08:20 PM
PC<->NC communication loky Mazak, Mitsubishi, Mazatrol 1 03-27-2007 03:44 AM
0mb to PC I/O cable and communication trouble goodplastics Fanuc 0 03-06-2007 02:12 AM
