Old 04-09-2009, 11:15 AM
greenchair is on a distinguished road
Hermle C40 Overtravel
Hello, we have a c40 that is taking a nap as it overtravelled in the Z-axis and we can't figure out how to free it.
Message
MC LIMIT SWITCH Z+
We are also getting a break test not performed message.
Any help appreciated
Old 04-09-2009, 08:44 PM
stevo1 is on a distinguished road
Look to see if you have a OT bypass or release button. You usually have to hold the button in and move the axis off the limit switch using the hand wheel if you have one. You should then be able to rest the alarm.
You also may have a swith that is stuck.
Stevo
Old 04-14-2009, 11:15 PM
hansdie is on a distinguished road
There are no limit switches just hit the CE key.
As for the "break test" there is a soft key in manual mode that you have to hit periodically.
Old 04-17-2009, 09:09 AM
Got it
Thanks for all the help but this issue required unpublished information from Hermle.
We had to increase the hard-coded allowable travel on the machine, wind it down a bit and set the allowable travel back to it's default.
This info is not given out as people have tried to artificially increase their travel by changing these numbers and have caused damage.
cheers
Sean
Old 10-26-2009, 07:04 AM
mordantly is on a distinguished road
this thread is old.. but the C40U is a fine machine. Fast and holds tenthousandths all day. My former employer had 2 of them.
MoRdAnTlY [Mr. Wolf '91 - '10]
Hermle spindle drive greenchair General Metal Working Machines 4 12-16-2008 08:37 AM
Hermle UWF700 ariesdenmark General Metalwork Discussion 0 11-22-2007 05:50 AM
Does any one have a Hermle UWF 1000 Repair_man General CNC (Mill and Lathe) Control Software (NC) 0 10-24-2007 07:22 PM
Does any one have a Hermle UWF 1000 Repair_man Deckel, Maho, Aciera, Abene Mills 0 10-24-2007 07:19 PM
5 axis post for a Hermle C 800 U swisssat Post Processors for MC 4 09-05-2007 08:53 PM
