Old 04-02-2009, 12:49 PM
carlosdcerna is on a distinguished road
Z-Axis Backlash Compensation on a Mill
Does anybody know if it is necessary to compensate for z-axis backlash?? I am wondering because gravity makes the whole spindle assembly pressed down. But what happens when the mill vertically enters material??
Can anybody help me??
Old 04-03-2009, 05:04 AM
spaceballs_3000's Avatar
spaceballs_3000 is on a distinguished road
Depending on your IPM, and material your cutting, it will not mill as deep as it should, thus creates weird patterns (valleys and dips.)
Old 04-03-2009, 05:17 AM
LeeWay's Avatar
LeeWay is on a distinguished road
You can use one of several different methods of taking the weight off the Z axis.
I personally use gas struts. Some use springs and others use a pulley and weight system.
I feel there is no need to counter the full weight of the Z axis as this would make the motor struggle on the down move, however if you have bad backlash, a heavier weight might just remove all of it out of the Z. This is as long as you aren't trying to cut too deep at a time.
Should help.
Lee
Need Help!- EMC Backlash compensation SpeedsCustom LinuxCNC (formerly EMC2) 9 01-19-2009 12:30 PM
Backlash Compensation solek Benchtop Machines 13 03-05-2008 01:22 AM
backlash compensation with slave axis jeb Mach Software (ArtSoft software) 2 03-04-2008 02:05 PM
Backlash Compensation cnccustom Mach Mill 1 11-21-2007 07:33 PM
